Electrical help with RT turn signal
I have the Russ Thompson turn signal on my coupe. Initially I had the stock lights etc. The system was all hooked up and worked as needed. I changed over to LED headlights,and I don’t know if it has to do with that, but the high beams are now just flash to pass. They don’t stay on.
Attached is the schematic that was used for the install.
Am I missing something?
