Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: need help with an idea
    Senior Member VD2021's Avatar
    Central, FL
    Quote Originally Posted by spytech View Post
    Aren't you Mr Fancy Pants Wiring Man
    lmao
    LOL.
    Just wish I had the same patience and skill for this body work stuff. I'm also tired of leaving the garage with itchy forearms....and I've been wearing old flight suits with the sleeve taped........
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Member spytech's Avatar
    Props for doing it on your own; I knew I wouldn't have the patience (or skill) for it, and I wanted it to look good, lol. Off to Ken's it went. Also helped me avoid builder'sburn-out
    Central, FL
    So that's what I had for the past three weeks..... Just glad it's not accompanied by the bubble guts.
    R/s
    Vidal
    Central, FL
    I was just brain storming and had some thoughts. The engine's throttle control is fly-by-wire. I'm curious if a simple circuit could be placed in line and activated by a swt that would limit the throttle by scaling down the input?
    R/s
    Vidal
    Quote Originally Posted by VD2021 View Post
    I have cruise, Full Active Handling with Competition Mode, ABS, Day Time Running Lights, Day light Sentential Auto Head lights. It's actually easier to state what's not on my build and functioning 100%. That would be magnasteer and the ride control system.
    Cruise control can be wired with a stock PCM, Outside of stock I'm not sure.
    Wow! Good stuff. Does active handling use the ABS and cut power? Have you been able to test?
    Member afourcault's Avatar
    Oklahoma City, OK
    this is going to sound crazy.. but if you have some rolled gauze.. wrap your arms in it might help used to do that to keep sand fleas off of my arms in iraq...
    Though you may try, you cannot break me. I am all that you wish you were but will never be.
    my prebuild/idea log
    Central, FL
    Quote Originally Posted by mmaragos View Post
    Yes. When I got to Kart stage I put about 25 miles on the GTM doing what I like to call "testing the systems". I could only get the wheels to spin with the system off or in comp mode. So far all of the systems work as described in the corvette manual. I also added a timed circuit that switches the system to comp mode when I start the GTM.
    R/s
    Vidal
    San Diego
    Please, DO NOT try and alter the drive-by-wire system in any way. It can have DEADLY effects.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Central, FL
    Quote Originally Posted by afourcault View Post
    Can't hurt to try it. I may even try saran wrap.
    R/s
    Vidal
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    V,
    Try some baby powder on your arms before working on the car. I doesn't solve the itching a 100% but helps a lot.
    GenII GTM #354
    Delivered (02/09/11)
    Fort Lauderdale Fl.
    Blow it off with the air gun and wash with cool water to keep the pores closed and you shouldn't itch..........Unless your a sensitive man!!!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    San Diego
    Yep. That's what I do, (blow and cold water wash) and unless I have been working all day, it works great. I've found for my longer days of body work that a barrier cream, or even just a lotion or sun screen tends to fill the pores and not let as much of the fibers in.
    www.myraceshop.com
    GTM solution kits
