Results 1 to 11 of 11
Thread: Just a few photos of my progress! Enjoy.
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Nice work on the cubby!
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by Lowrod View Post
    Wow, that is a nice, large cubby. I'm about to do mine and was only thinking of a box the width of the distance between the two inboard roll bar mounts but pretty deep, basically filling in where the battery would sit if I were not dropping it into a box. This has me thinking of some other options. Thanks for sharing.
    Mark Eaton's Avatar
    Medford, Oregon
    Lowrod,
    Looking really good. I'm actually working on a similar cubby. I got the idea at the Huntington Beach Rally.
    Mark
    I did similar on my old MkII but I left the 3/4x3/4 tube in place. You can't put as large a solid object in there but it works fine to throw in a folded up coat, hat etc.
    Nov 2015
    Mount Olive AL.
    Coat/hat storage was the idea, I bent a length of 3/4 tubing to match the body arch. It was then welded just behind the body rolled edge of the rear cockpit. I plan on adding two metal plates to support driver and passenger seat belts.
    NY
    Nice work!
    RJD's Avatar
    Northern Virginia
    Love your cubby.
    I added a locking access panel to the Breeze cubby kit. While the door is a little small, it won't interefere with the seats.
    Oct 2017
    Quote Originally Posted by RJD View Post
    Love your cubby.
    Where did you get the locking access panel?
    Dreaming.... Duck62's Avatar
    Sep 2018
    Aiken, SC
    This is a must have with my wife!
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by dhuff View Post
    On line at Boat Outfitters.
    I removed the white tub to give me access to the Breeze cubby, although leaving it on gives you a nice small compartment. The tub comes off by removing a couple of screws.
  12. Thanks dhuff thanked for this post
