quad bracket.jpgHi guys I noticed the placement of the rear hole in the 02 quad mount appears higher than the photo in the coupe build manual. Will mounting it like that throw the geometry off too much or should I redrill it. If I need to redrill can you give me an aproximate measurement from the top edge. Also do i retain the stock sway bar when using the 4 link?
