Anyone has a the wiring schematics and pin out for the steering column connectors of the C5?
Are you referring to the harness I talk about in my post here?
http://www.gtm-supercar.com/?p=421
I can get the full pin-out later if you still need it from my c5 service manual.
That is the one. Thanks Spy.
Here is the complete pin-out:
Connector Part Information: #12092248 23-Way M Metri-Pack 280 Series (BLK)
Pin Wire Color Circuit No. Function
A WHT 27 Hazard Flasher Output
B DK GRN 19 Stop/Turn Lamp Feed-RR
C YEL 18 Stop/Turn Lamp Feed-LR
D PPL 16 Turn Signal Flasher Output
E -- -- Not Used
F DK BLU 15 Turn Signal Lamp Feed-RF
G LT BLU 14 Turn Signal Lamp Feed-LF
H DK BLU 38 Cornering Lamp Control Feed
J BLK 58 Cornering Lamp Feed-Right
K LT GRN 11 High Beam Headlamp Feed
L TAN 12 Low Beam Headlamp Feed
M -- -- Not Used
N BLK 150 Ground
P -- -- Not Used
R BRN 9 Park Lamp Feed
S WHT 103 Headlamp Switch Signal-"On"
T DK GRN 306 Headlamp Switch Output-"Off"
U ORN 57 Cornering Lamp Feed-Left
V BLK 28 Horn Relay Output
W RED 842 Battery Positive Feed
X RED 842 Battery Positive Feed
Y LT BLU 74 Park Lamp Switch Output
Z ORN 240 Battery Positive Feed
thanks spy.
GenII GTM #354
Delivered (02/09/11)
no prob
