Thanks Thanks:  16
Likes Likes:  74
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 124
Thread: Les’ Nor Cal Wine Country 33 build #1121
    Member Mrallsport32's Avatar
    Aug 2017
    Cotati California
    Side venting
    First, your shop is far too clean. I clearly need to spend a number of hours cleaning mine.
    Second, you mention vents. JimLev's build thread has a few comments on the one's he's using which look great. That is one of the options I'm considering. The other option (and the one my wife favours) are Buick "ventiports" which I saw on a 33 somewhere but darned if I can find the pic again. However, these don't seem to be open so they would be purely cosmetic unless I modified them.
    http://www.oldbuickparts.com/product...roducts_id=284
    Attachment 120628
    Is that along the lines of what you were thinking. I believe they are available in different proportions too depending on the model year of buick, some longer and skinnier...
    Actually now, after looking around on the interwebs, I’m liking the Buick portholes. They can be easily modified to be opened up and functional to allow heat to escape.
    Note: also the not so clean part of my shop was hidden behind the camera. Haha.
    Gen 2 chassis #1121 delivered 2-10-19. SBC 400 with FI Tech dual quad, 700R4 trans and IRS.
  2. Likes FF33rod liked this post
  3. #82
    Jun 2018
    North Vancouver, BC, Canada
    Yeah, sounds like you emailed them as did I. They said no problem.... Think that's what I've settled on...
    Gen 1 '33 Hot Rod #1104
  4. Likes Mrallsport32 liked this post
  5. #83
    Aug 2017
    Cotati California
    So Not much has really changed on my car lately. I’m kinda of waiting for the car to go to the paint shop, which should be in a couple of weeks hopefully.
    Thought some levity is needed in these times, as we are quarantined here in Northern California. They even shut down my golf course. 🤣
    I hope everyone stays safe.
  6. Likes HVACMAN liked this post
  7. #84
    Falmouth, MA
    The brake cleaner works fine but the (acetone) really dries out my skin. Maybe rub in some good old #90 differential oil for moisturizer.
  8. Likes AJT '33, Mrallsport32 liked this post
  9. #85
    Aug 2017
    Cotati California
    Wiring and the build goes on and on.
    So I had my car ready for the body shop in January.
    [ATTACH=CONFIG]130158[/ATTACH
    The plan was To take it in to paint shop, then when the body came back off for The finish work, I would bring the chassis back home to complete wiring and go kart it. Well best laid plans didn’t work out. The body shop got backed up and couldn’t take the car in , which he apologized for, and then the pandemic hit. So the car sat, thinking it would be any week for it to go to the shop. That didn’t happen.
    So, now I have taken my car back Completely apart with the body off to complete all the wiring/plumbing and fix some other things I didn’t like. Boy I never realized how much I dislike wiring and I have it simple compared to most. Haha.
    F4F82766-BA07-4BF4-88E0-17CA4286D53C.jpg.
  10. Likes FF33rod, JOP33 liked this post
  11. #86
    Senior Member JOP33's Avatar
    Haslet, Texas
    Wiring builds character!
  12. Thanks Mrallsport32 thanked for this post
  13. #87
    Jun 2018
    I'd happily do the wiring for someone if they in turn do the body fitting, void filling, hardtop fitting and power windows.... Hmmm, now that I say it, it does sound a little lop sided....
  14. Thanks Mrallsport32 thanked for this post
    Likes Mrallsport32, JOP33, AJT '33 liked this post
  15. #88
    Aug 2017
    Cotati California
    It’s alive. First start.
    https://drive.google.com/file/d/17G1...w?usp=drivesdk
    So I got the SBC 400 up and running. It wasn’t without some issues. I had trouble matching the holly sniper dual quad to the aluminum heads. First the intake Flange wasn’t near being straight. Then the intake runners were not big enough to cover Head intake runners which are 2.23 tall. So I had a machine shop add material on the top edge and Re-size and then re-deck the Flanges to square. But I have to say, it did fire right up. The FI tech seems to be programming itself with no problems or leaks anywhere. So far so good.
    https://share.icloud.com/photos/0Gzq...7SSyBX7avCdWoA
  16. Likes JimLev, FF33rod, sethmark liked this post
  17. #89
    Placitas, NM
    Sounds excellent, nice idle.
    What cam are you using?
  18. #90
    Senior Member sethmark's Avatar
    Virginia International Raceway
    I hear a little Tim the tool man!
    that exhaust is absurd. So throaty....
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
  19. Likes Mrallsport32 liked this post
  20. #91
    All I see is "access denied"
  21. #92
    Jun 2020
    SoDak
    Sounds great....Do you have to sync / balance the dual Fi-Techs somehow or is it controlled?..... electronically?
    Also, what brand are the quad exhaust tips? Looks like my stock ones on my a C6 vette?
    Big moment, great job!!
  22. #93
    Placitas, NM
    Quote Originally Posted by sread View Post
    The second link works.
    First link looks like it wasn’t made public.
  23. #94
    Aug 2017
    Cotati California
    Welp, I was looking for the cam card and couldn’t find it. It’s nothing too radical just a little more duration in the cam. I’m an old circle track racer and our machinist always liked big duration in his cam to help with our Torque monster engines. When I find the cam card I’ll post it.
  24. #95
    Aug 2017
    Cotati California
    I Don’t have to do anything with the FI Tech system. They plug into each other and the built in computer system is self learning. so far (fingers crossed) it seems to be working fine. It has a little hand held type controller that is about the size of an IPhone that shows me everything. I can also do any tuning with it.
    Welp, I’m not sure what those exhaust tips are from. A good friend owns a very well known and Long established exhaust shop(s) hear in nor. Cal. (Johnny Franklins Mufflers). I just dropped the car off at his shop saw those tips on the wall and left the rest up to him. I had no other input on the exhaust at all, he custom made the whole system. The best part is he wouldn’t give me a bill. A lot of people have said they look like the vett.
  25. Likes FF33rod liked this post
  26. #96
    Jun 2020
    SoDak
    Quote Originally Posted by Mrallsport32 View Post
    Nice..... I have the Holley Sniper System on the my 70 Challenger...just single carb though, but similar with the programmable handheld. Good to know they plug and play together and the ECU does all the syncing.
    The exhaust is really nice...sounds great too. Nice job!!
  27. Thanks Mrallsport32 thanked for this post
  28. #97
    Aug 2017
    Cotati California
    Welp, I finally got the car into the body shop. I’ve been waiting since February. Now It’s Kinda weird with no hotrod in the garage. Anyway With the COVID (bs) and fires here in California stuff got backed up.
  29. #98
    Aug 2017
    Cotati California
    Last shot.
    Last picture before it went to the body and paint shop.
  30. Likes wrp, JOP33 liked this post
  31. #99
    Aug 2017
    Cotati California
    Making progress
    Ok, so, this is the, I haven’t posted in a while post. Hot rod went in to the body shop in Sonoma Ca. on September 20th, 2020. Today is May 22, 2021 and we (they)finally started final assembly before coming apart for paint. And yes, I made some changes while it was at the shop, also with COVID era things seem to take longer. But I’m very happy with the way it’s coming together. Pictures are with everything in place just not all tightened or lined up yet.
    029C257D-BF6C-4AEC-9BFF-29626E3A1176.jpg5AC52DA7-F007-4725-AF5B-DA44145A5966.jpg8364D785-D5B9-4C49-A2A4-2941A86F99D2.jpg770ABD1A-04C5-4352-8096-27E764A90EFD.jpg
  32. Likes 33fromSD, Tampa33Build, FF33rod liked this post
  33. #100
    Dang 8 months must be tough to deal with. But looks good!
  34. #101
    Nov 2020
    Los Angeles
    Congrats on your start of the build, I will be starting in about 30 days. My kit is scheduled for delivery toward end of June. I look forward to following your build!!
  35. #102
    Aug 2011
    San Jose, CA
    Any updates? I am looking for an excuse to drive up to your area in my Hot Rod. When you get the car back from paint and do not mind a social distance visit from a fellow hot rodder, I would love to drive up.
  36. #103
    Aug 2017
    Cotati California
    Quote Originally Posted by Brastic View Post
    No real update. The shop my car is at closed three different times due to employees getting sick from COVID.
    Last week the car came apart for paint. Hopefully see some color the beginning of January. As soon as it’s done I’ll post it. Then come on up.
  37. #104
    Jan 2016
    I have really enjoyed your build. I have a similar SBC underway with a 700r4. I believe I saw a side view of your transmission in one of your 2020 posts. It looks as if you have a short transmission dipstick and tube. I have been looking for something like this. Do you recall the brand? Has it been working ok? These seem to keep the firewall cleaner. Most of the standard ones I see are almost too long for these cars. Thanks.
  38. #105
    May 2019
    Quote Originally Posted by Indigo808 View Post
    Look at Lokar for the dipstick.
  39. #106
    Aug 2011
    San Jose, CA
    I was driving through the Napa area this weekend and was thinking of your build. Actually, I have been attending the Breakfast Club Rallys in Sonoma and have been really enjoying driving the hot rod through Northern California. Once you are on the road, it would be great to see another hot rod. So far, with all of the drives and shows I have been attending, I have been the only one.
  40. #107
    Aug 2017
    Cotati California
    The transmission dipstick is from lokar. It works fine. Part# Loktd3700tm
  41. #108
    Aug 2017
    Cotati California
  42. #109
    Aug 2017
    Cotati California
    Decided to add a pearl white stripe.
  43. Likes FF33rod liked this post
  44. #110
    Aug 2017
    Cotati California
    Welp it’s pretty much done.
    The car is pretty much done. There is just a few things to do.
    This is how I picked the color, it’s the hand soap in my garage.
    The Paint really looks much better in person. The pearl in the paint doesn’t show up in the pictures.
    C06496B5-EE7D-433B-9D0A-687D2B5EF5B0.jpeg6D7C23A4-F433-4794-8D8B-55A93A4EBD3F.jpg4F94A16D-EAB9-4EC7-B2C2-1B7FA000B35B.jpg
  45. #111
    Aug 2017
    Cotati California
  46. Likes Fman, FF33rod, JOP33 liked this post
  47. #112
    Aug 2017
    Cotati California
    Spare door for garage wall.
    Like a lot of guys I got one of the twisted doors that I couldn’t make fit satisfactory. factory five was able to send me a new one right away. I then used the twisted door as a test for the first paint spray out. So I decided to hang the test door in the shop with stickers from all the different manufacturers parts I used on the build.
  48. #113
    Aug 2017
    Cotati California
    The hot rod is in Idaho right now I’m bringing it back in July.
  49. #114
    Simi Valley, CA
    I like your use of the spare door, but where's the Factory Five Racing sticker? (They used to pass them out at car shows, etc. They might send you one if you ask nicely.)
    Keith HR #894
  50. #115
    Aug 2017
    Cotati California
    Keith HR #894
  51. #116
    Simi Valley, CA
    Hmmm? Different from what I'd seen before. Maybe FFR has a whole series of them. Very cool, in any case.
    Keith HR #894
  52. #117
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    Great looking hot rod, that color combo is fantastic! Hope you are enjoying and putting some miles on it.
  53. Thanks Mrallsport32 thanked for this post
  54. #118
    Jun 2018
    Looking fantastic Les, inside and out! Love the idea of using the spare door for stickers - was wondering what I was going to do with both of those!
  55. #119
    Aug 2017
    Cotati California
  56. Likes 33fromSD, Tampa33Build, Brastic liked this post
  57. #120
    Aug 2017
    Cotati California
    Some Sonoma wine country shots
