Results 1 to 5 of 5
Thread: 1964 Shelby Cobra USRRC by Factory Five
    Junior Member Clark L Creswell's Avatar
    Jan 2018
    Melbourne , Florida
    1964 Shelby Cobra USRRC by Factory Five;
    Mark IV Chassis
    Black Powder Coated Panel Through out
    Not more then 800 miles
    Fresh 1968-Ford 289 cu. in.
    Aviad 8.0-qt. Oil Pan
    Mellings High Volume Oil Pump
    M-6250-E303 Cam Grind Number with Comp Roller Lifters
    MSD 6-AL Ignition
    MSD Pro Billet Dist. (P/N 8579 Proper Steel Gear Installed)
    3" x 14" K/N Air Filter
    Earl's Perf. Temp-A-Cure Oil Cooler (81300a )
    Tremac 5-spd. Trans
    M7550-t302 Ford Performance Clutch
    M-6375-b302 Ford Performance Flywheel
    Moser 8.8 Differential Assembly with WaveTrac*
    FFR Deluxe 3- Point Rear Suspension
    Koni Shocks at 4-corners
    USRRC Dash fitted with 2-5/8" Stewart Warner Gauges
    Russ Thompson Turn Signal Switch
    Vintage Pin Drive FIA Wheels mounted with Mickey Thompson Street Radials front 26 x 10.00 x 15 , rear 26 x 12.00 x 15
    PBR Front Brake Calipers / Rear Calipers Emer. Brake Capable
    Wilwood Pedal Assembly (P/N 340-11299) , Wilwood Remote M/C Kit
    This is a quality build with documentation of same "no donor parts" . The car is registered as a 1965 and carries Antique plates in Fl . with a "Clean Florida Title" . Any requests for additional information will be honored within 24-hours usually less . Please Serious Inquires Only !
    Asking $39,600.00
    Apr 2019
    i left you a private message
    Apr 2019
    is this vehicle still for sale?
    May 2019
    Well I'm jealous of whoever gets that! Also you're garage is immaculate.
    Accord NY
    Does anyone know what color the car is?
