Thanks Thanks:  7
Likes Likes:  54
Results 41 to 80 of 83
Thread: Matt's '36 Hotrod Truck build
    Senior Member ztoolman44's Avatar
    Apr 2019
    Summerland, BC
    Also threw on the steering column, shafts and steering wheel. Most things fit great, the uppermost shaft seems a bit short. Where all of the other shafts are fully seated, the top one is about an inch short and I have to center it between the two u-joints. Might be able to play with that a bit on final assembly, just mocking up for now. Turns very smoothly with no binding at all. Definitely going to need stops installed, its a drift car right now till the tires contact the control arms.
    Apr 2019
    Summerland, BC
    Quote Originally Posted by Pat Landymore View Post
    That’s looking great Matt!
    Noticed some very meaty tires in the background....
    Do you have plans for NOS or Boost in your future?
    Lol, those were on the truck when I bought it. It had a typical 80's hot rod set up. Camaro clip in the front with 14" rally wheels and those giant Craigers on the rear. I gave the old frame to a guy in town with a bunch of old cars for future trade but kept the rims. They are just too cool.original chassis resized.jpg
    Very interested in adding boost down the road though. Just want to get it all together first.
    Sep 2019
    Houston, TX
    Cobra brakes would be a nice upgrade. Find you a rebuild kit for the calipers and resurface or replace the rotors and you will be good to go. Make sure your wheels will clear the larger calipers, should not be a problem if running 17” or larger. Nice to see you progressing on the build!
    Apr 2019
    Summerland, BC
    Quote Originally Posted by McGuyver View Post
    That's my thoughts as well. I'm going to use the Cobra rims for now so no issues there. Thanks
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    I had the same issue with my upper steering shaft.
    Partly because I’m paranoid, I drilled counter bores at each set screw location so they would truly bite well into the shaft, then Locktited them. Ended up purchasing bulk shaft material and making my own upper shaft so that everything felt correct in my mind.
    Aug 2019
    Alvin, Texas
    I'm not sure on the brakes....but I can tell you that you are gonna have trouble with your pinion flange. I had the same one and it does not fit the driveshaft or driveshaft adapter. I had to order a 2009 GT500 pinion flange (6-bolt).
  7. Thanks Bob Loutonx2 thanked for this post
  8. #47
    Apr 2019
    Summerland, BC
    Yeah, it makes it to the set screws but I am not comfortable with that. My plan was to make a longer shaft.
  9. #48
    Apr 2019
    Summerland, BC
    Quote Originally Posted by RuffShod View Post
    Agreed. My plan is to change the pinion flange to a u-joint and get rid of all the adapter stuff. Since I am modifying the driveshaft anyway, might as well just put a proper end on there. Thanks.
  10. #49
    Apr 2019
    Summerland, BC
    Decided to go with the Cobra brakes in the front. Rebuild kit with pistons for ~$25. If anyone needs some brand new GT stuff that comes with the FFR kit, let me know. Rotors, calipers, brackets- willing to make a someone a sweet deal. LOL
  11. #50
    Apr 2019
    Summerland, BC
    Think I came up with a method for cleaning old hardware. Not a big fan of painting nuts and bolts. Let's see how these last.
  12. Likes RuffShod, Pat Landymore liked this post
  13. #51
    Aug 2019
    Alvin, Texas
    Quote Originally Posted by ztoolman44 View Post
    Did you apply any heat to them? I am wondering because I am getting into cerakote and anodizing and the end process is heat.
    Just curious....
  14. #52
    Apr 2019
    Summerland, BC
    Just curious....
    I considered doing a hot process but decided with suspension and brakes it would be safer to try a cold process. Essentially just bluing like you would with a gun.
  15. Likes RuffShod liked this post
  16. #53
    Apr 2019
    Summerland, BC
    My donor rear end did not come with brakes. Ordered new from Summit and installed then put the rear under the truck.
  17. Likes RuffShod liked this post
  18. #54
    Apr 2019
    Summerland, BC
    Finally have a roller. Felt like a big victory to get to this stage and push the rig out into the sunlight.
  19. Likes RoadRacer, RuffShod liked this post
  20. #55
    Apr 2019
    Summerland, BC
    Received the parts to rebuild the front calipers. Went with the VHT paint system and had zero issues. Lots of prep plus the appropriate "baking" process and it seems to be holding well and looks great. Time will tell.
  21. #56
    Apr 2019
    Summerland, BC
    Installed. The 1994 Cobra parts fit perfectly. Rebuild parts from Rockauto.
  22. Likes RoadRacer, Pat Landymore liked this post
  23. #57
    Dec 2018
    SW Calgary, AB
    Your project is looking great!!
    One question tho...isn’t that a gas oven in your photos?
    I’d be concerned that a gas oven plus paint fumes flashing off is a nice invitation for a visit from Mr. Ka Boom!! LOL 😂
    Sure you had that all under control.., 😁👍🏼
    Pat
  24. #58
    Apr 2019
    Summerland, BC
    I’d be concerned that a gas oven plus paint fumes flashing off is a nice invitation for a visit from Mr. Ka Boom!! LOL ��
    Sure you had that all under control.., ������
    Pat
    Lol, yeah I did do some soul searching first but the firefighter in me concluded that there shouldn't be a difference in a gas or electric oven in regard to the flammability of the off gassing so why not give it a go. If the paint is safe to bake at a given temperature is must not be anywhere near reaching the flash point of the vapors so why would it matter if the heat is generated by fire or induction? Not sure if the flames have a temp higher than the element during the heat up portion but I got the oven to temp first then put the items in there.
    Now the smell in the house when the wife got home had me more worried.
  25. Likes RuffShod, Pat Landymore, WIS89 liked this post
  26. #59
    Apr 2019
    Summerland, BC
    Been quietly working away in the shop when I have a minute here and there. No wild build here, just trying to be budget conscious so only repair what is broken or obviously worn. Trying very hard to stop project creep, you know the ol', "while I'm this far, might as well do this or that". Getting ready to marry the engine and trans and get them in so I can start on the body. Needed those in for fabrication of the big items like firewall, floors, trans tunnel etc. I'll get most of the fab work done before plumbing and wiring anything but did not want to mock up with a bunch of dirty bits.
  27. Likes Pat Landymore, WIS89, RuffShod liked this post
  28. #60
    Dec 2018
    SW Calgary, AB
    Wow, those look brand new! Nice work 👍🏼👍🏼
  29. Thanks ztoolman44 thanked for this post
    Likes WIS89 liked this post
  30. #61
    Apr 2019
    Summerland, BC
    A few more glamour shots. Will be installing the new clutch and putting them in the car when I get home next week. Hope to get the drive shaft modified as well then on to the body mods and get this thing looking like a truck.
  31. Likes Pat Landymore, RuffShod liked this post
  32. #62
    Dec 2018
    SW Calgary, AB
    Awesome work!! All factory fresh goodness 👍🏼👍🏼
  33. #63
    Apr 2019
    Summerland, BC
  34. Likes Pat Landymore liked this post
  35. #64
    Apr 2019
    Summerland, BC
    Only one small issue and that is the passenger side header hits the motor mount bracket. Could be resolved with a BFH but I am hoping the community has some words of wisdom or alternative part options. I want to keep this on budget but am not entirely convinced that a dented header is the best way to proceed.
    Brand new motor mounts and everything else lines up so I am not able to wiggle the engine to one side or the other. It is where it is. The trans is sitting on a new trans mount and everything appears to be at the correct level in relation to the chassis. I tried flipping the trans cross member and it just made thing all out of whack so I believe it is installed correctly.
    Thanks in advance for any advice.
  36. Likes Pat Landymore liked this post
  37. #65
    Apr 2019
    Summerland, BC
    driveshaft adapter resized 2.jpgdriveshaft adapter resized.jpgnew yoke resized.jpg
    The supplied kit adapter did not fit the 2014 rear end or the 1994 drive shaft so after looking at options I decided to just get rid of the whole lot and bought a new yoke. Much cleaner and cheaper than trying to cobble a bunch of parts together. Time to send the driveshaft off to be shortened.
    Heading back to work for a few weeks but it is almost time to start forming some metal and making this thing into a truck.
  38. #66
    Placitas, NM
    MotorTrend has a series called Engine Masters where they did exactly that. They dyno the engine then used a BFH to dent a header tube then measured the HP/torque again. IIRC it was only down 2 HP or less.
  39. Thanks ztoolman44 thanked for this post
  40. #67
    Apr 2019
    Summerland, BC
    Saw that episode and feel like it is a viable option, just not an attractive one. Hoping for someone to tell me that there are some other factory manifolds or inexpensive headers.
  41. #68
    Aug 2019
    Alvin, Texas
    I had the same driveshaft issue. I bought a new pinion flange.
  42. Likes ztoolman44 liked this post
  43. #69
    Apr 2019
    Summerland, BC
    Before I cut out the firewall, I made some templates to have some reference points for later.
  44. #70
    Apr 2019
    Summerland, BC
    The firewall was full of shoddy repairs and the attempt to fill the fuel neck is rough but otherwise only one small area to patch.
  45. Likes RuffShod liked this post
  46. #71
    Apr 2019
    Summerland, BC
    roll bar removal 1.jpgroll bar removal 2.jpgroll bar removal 3.jpgroll bar removal 4.jpg
    This cab is an entirely different shape than the FFR cab and the roll bar will not work as is. So off it comes.
  47. Likes RuffShod liked this post
  48. #72
    Apr 2019
    Summerland, BC
    Before I cut out the floor and firewall of the cab and then section it, I need to lock in the door openings. Overall the length from firewall to back of cab is pretty close however I will need to widen the entire thing by almost a foot. I am using the chassis as a table to have the cab at a convenient work height.
  49. Likes RuffShod liked this post
  50. #73
    Dec 2017
    Southern Ontario
    Get that man a Bud Light!!
    Reminds me of my old Ford!
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
  51. Thanks ztoolman44 thanked for this post
  52. #74
    Apr 2019
    Summerland, BC
    I just cut the whole piece out. I'll fab up a new drive shaft hoop later.
    Edit- I thought you were talking about the spot where the driveshaft hit the cross member. On the rear end I changed to a 1330 style pinion yoke and had my drive shaft rebuilt to fit. Got rid off all the weird Ford stuff.
  53. Likes RuffShod liked this post
  54. #75
    Dec 2018
    SW Calgary, AB
    Nice update Matt!
    When you say widen by a foot…are you talking about the entire cab?😳
    Or do you just need to reshape the bottom to clear the FFR frame rails?
    All in all, major kudos for taking on the version of the project I now wish I had!
    It’s looking great 👍🏼
  55. #76
    Apr 2019
    Summerland, BC
    Nice update Matt!
    When you say widen by a foot…are you talking about the entire cab?��
    It’s looking great ����
    Widen by a foot is just what it sounds like. The truck cab is much narrower than the chassis, especially at the firewall (around 12 inches). I will need to stretch the distance between the A-pillars about eight inches or so. The rear of the cab is not as drastic, maybe 2 inches. Distance from the firewall to the back of the cab is pretty close. It appears as though FFR squared up the cab and started the angle to the grill at the A-pillar. The original cab is kind of wedge shaped from back of cab all the way to the grill.
  56. #77
    Apr 2019
    Summerland, BC
    Hinges 1.jpgHinges 2.jpgHinges 3.jpgHinges 4.jpgHinges 5.jpgHinges 6.jpgHinges 7.jpgHinges 8.jpgHinges 9.jpg
    In order to lock in the door dimensions, I need to install the rockers. In order to install the rockers, I need to install the doors. Well, the hinges are over 80 years old and needed some love before they would give consistent gaps. They did not want to come out without a fight though.
  57. Likes RuffShod, Pat Landymore liked this post
  58. #78
    Apr 2019
    Summerland, BC
    Turns out the doors were just as wonky as the hinges. Tried to get the big dents and twists out so that the hinges slide in without binding and the frames fit the door openings the best I can. No more oil canning so I must be on the right track.
    I'll tackle the small dents and fill holes down the road. Plenty of welding to come.
  59. Likes Pat Landymore liked this post
  60. #79
    Apr 2019
    That’s awesome, definitely going to watch your thread with great interest.
    Jeremie
  61. Thanks ztoolman44 thanked for this post
  62. #80
    Dec 2021
    I was regularly baking paint in a previous lifetime and had the same concerns. Looked for and found an electric countertop oven for $15 at a yard sale. Worked great and the wife is happy, too.
  63. Thanks ztoolman44 thanked for this post
