0
0
Wrong fuel pump?
I have 818 # 107. I replaced the gas tank with the new tank. The sensor and fuel pump for the original tank don’t fit the new tank. I went to my local junkyard and asked for the sensors out of a 2003 tank. When I got it home and then looked in the manual. The top of fuel pump in all the photos in the manual and on the forum show 3 tubes. There seems to be a disagreement about what each one does. My fuel pump sensor has only 2 tubes. What did the junkyard give me?
I am also confused about venting. There are so many options on the forum.
Originally Posted by
Hojo
The pump assembly below on the left is out of a 06 NA (normally aspirated) Impresa. 2 ports (pump out and Jet pump in)
The pump on the right is out of an 04 FXT Turbo. 3 ports. (pump out, return and Jet pump in)
Below is my tank with labels for my turbo setup.
- You may not post replies
- You may not edit your posts
Forum Rules
