Thread: No power?
Hybrid View
    Millis, MA
    No power?
    Well I’m stumped. Car wouldn’t start, seems the cheap battery wouldn’t hold a charge. Bit the bullet, bought an Odessey yellow top, putting out 13.6 volts. Try and start the car cranks for maybe 1/2 a rev, and then nothing, and I mean NOTHING. No cranking, no instruments, no lights, no horn, nothing. Power at the battery, power at the positive distribution block. Any thoughts or suggestions would be appreciated.
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
    Quote Originally Posted by chuckster View Post
    You've got a bad connection somewhere - breaking down under high amperage load.
    Especially watch the negative side too - depending on where the battery is, it make take two or three people + 6'-10' meter leads to isolate the problem(s?).
    Port Charlotte, FL
    Chuck,
    As Mike eluded to above, check your grounds. Do you have a ground from the engine block to the frame? How long is the negative cable from the battery to the frame? Did you grind away the powdercoat wherever you have a ground connection?
    Thx,
    Henry
    Millis, MA
    Thanks folks, bad solder joint on the block to frame ground cable.
    “Privateer”
    Jul 2019
    Thanks folks, bad solder joint on the block to frame ground cable.Visit this link to find the best battery tender that you may concern.
    Glad to hear you solved this problem.
    Now that you've solved the problem, I don't need to start at the top of the typical troubleshooting list...
    "Is it plugged in?"
    Glad you got it resolved.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
