Results 1 to 3 of 3
Thread: For sale FFR MkII w/ 408 and 2015 IRS
    Body
    Silver w/ wine stripes
    APE hardtop painted to match body
    Daytona Bill rear flares
    Dropped butt mod
    Quick jacks deleted
    Trunk expanded downward over left side of gas tank w/ hinged double panel lid
    Engine / Trans
    408W stroker kit from Coast High Performance in 1984 351W block installed winter 2015-2016
    Performer RPM heads and intake. New springs and seals done w/ 408
    Quickfuel SS 750AN (650 main body included)
    Mechanical fuel pump new w/ 408
    TKO 500
    Suspension- Front
    FFR tubular LCAs
    FFR spindles, hubs w/ UCA frame mount mod to current FFR specs
    QA1 adjustable upper ball joints
    QA1 double adjustable coil over
    Multiple coil over springs from 600 to 800#
    UCAs current FFR style from SPC
    Ackerman mod done
    Sway bar Forte 1” on car and 7/8” goes with
    Suspension- Rear
    Upgraded to 2015 IRS winter 2016-2017
    3.15 diff
    QA1 Double adjustable coil over w/ bump strength reduced via special re-valve by Naake Suspension
    Multiple springs 300 to 500#
    Note the DA shocks make an easy way to go from an autocross setup to a smoother street setup.
    Interior
    Driver seat Ultra Shield aluminum race seat modified for easier in/out
    Passenger seat Corbeau GTA Lo Back w/ head rest
    Cubby behind seats
    Silver carpet
    Earl’s door panels
    Hidden lighter outlet
    Dual heaters w/ separate fan switch for driver and for passenger
    FFR leather wheel
    Wheels / Tires
    Three sets;
    Street; Anthracite Bullitts. Front = 9x17 w/ 275 Sumitomos. Rear = 10.5x17 w/ 315 Mickey Thompson Street Comp. Also another set of older Bullits 9" and 10.5"
    Autocross; Front = 10.5x17 Anthracite Bullit w/ 315 Hoosier A7, Rear = Levy 11x17 w/ 335 Hoosier A7
    Brakes
    Front- Fox single piston calipers w/ Hawk HP+ pads. New never installed PBR calipers in box.
    Rear- 2015 Mustang OEM calipers w/ Hawk HP+ pads
    CNC balance bar adjustable dual MCs w/ cockpit adjust wheel
    Frame
    Late MkII w/ trans tunnel backbone frame
    Many upgrades to increase rigidity per Dave Borden’s CAD design as well as diagonals at door opening similar to current FFR design
    20200308_121053.jpg20200308_121219.jpg20200308_121248.jpg20200308_130421.jpg20200308_130524.jpg20200308_130618.jpgTrunk 1.jpgIMG_20160128_140118297.jpg
    $30,000
    Contact via PM or email to craigstuard at comcast dot net w/ FFR as subject.
    Grand Rapids, MI
    Craig,
    Huh?? Hope you're going to build something new. You've been an inspiration and source of great assistance.
    Good luck with the sale.
    Jim
    Jun 2017
    Does this car have a title for the street. Hope I asked the question right.
    I want to know if the car can be street registered. Thank you.
