Thanks Thanks:  2
Results 1 to 6 of 6
Thread: QA1 Bump Stops
    Sep 2015
    Bridgewater, MA
    QA1 Bump Stops
    Guys,
    I ordered the QA1 package from Dan Ruth. I noticed that the QA1s do not come with bump stops. Is the 0.875 long / 1.9 wide the correct one to order?
    https://www.qa1.net/automotive/suspe...ies/bump-stops
    Sean
    '33 Hot Rod Gen 2 Roadster #1209, 33 Grill, 3-Link Rear Suspension, Leather Roadster Seats, Electric Assist Steering, Rear Exhaust, 2 Piece FFR Bonneville Wheels (18x9/20x11) Mickey Thompson Street Comp Tires (255/45/R18 and 305/35/R20), '69 Ford 351w (Stroked to 393. All Forged), AOD, 8.8 31 Spline Rear with Trac-Lok, QA1 PromaStars (Front 9" 220lb/Rear 12" 200lb Springs).
    Quote Originally Posted by shmelty View Post
    Guys,
    Sean
    I use the same QA1 shock front & rear and installed the QA1 BC02 bump stops all around which works for my application (and matches your description): https://www.summitracing.com/parts/qa1-bc02
    But the BC01 will give you a larger tuning window if you think you need that: https://www.summitracing.com/parts/qa1-bc01?rrec=true
  3. Thanks shmelty thanked for this post
    Sean, I know nothing about Dan Ruth's coilover kit but can give you some tips on your front set-up. I run the double adjustable QA1 Proma Star #DD403 shock on all four corners (my rear suspension is my design) and on the front I run these inverted so the adjusters are easy to access. To run the shock inverted you have to run a shorter spring and use the QA1 extended spring caps https://www.summitracing.com/parts/qa1-9018-113
    I also run 250 lb/in springs on the front as the stiff springs FFR supplied in the kit are more suited for a 1-ton truck. The 250 lb/in are a little too stiff and I'll likely change them at some point but they are working and give me much improved weight transfer off the front (and a much better ride on the street).
  5. Thanks shmelty thanked for this post
  6. #4
    Sep 2015
    Bridgewater, MA
    Thanks NAZ! I will order those bump stops. Dan offers different spring rates and i went with slightly softer than FFR per his recommendation. His fronts also come with the appropriate caps to mount upside down for easy adjustment.
  7. #5
    Nov 2018
    NAZ Do you have any front qa-1 pictures ,,,I am in the process of change over mk-2 front ,,,I have the DD403 FOR FRONT ,and trying to figure out the mounting to lower... thanks
  8. #6
    Placitas, NM
    Post 2 & 6 may help you.
    NAZ hasn’t been here for quite a while.
    https://thefactoryfiveforum.com/show...cks-Which-ones
