Results 1 to 2 of 2
Thread: Front UCA ball joint....
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    The ball joint on the drivers side fit fine, but the passenger side is about 1/10" less engaged so the cotter pin hole is blocked by the castle nut with the washer. If I remove the washer it works. Is the washer necessary, or should I get a thinner washer? I pushed the boot out of the way to get a look from the top, and it's definitely fully seated. SN95 spindles if that matters. Thanks.
    MK3.1 #7076 - Under Construction....
    Coyote 5.0/Solid 8.8/Tremec 3650
    How to:
    Coyote Power Steering
    05-09 T3650 in a Roadster
    Fort Lauderdale Fl.
    try a thinner washer first.
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
