5
100
Thinker of thoughts
Originally Posted by
Ajzride
I went through a lot of trouble to make mine so that there was nothing below the car and it was all in the passenger compartment, but I'm thinking it would have been better to have done what you did. Those little bolt heads being under the car shouldn't be an issue and it looks way faster to fabricate.
When I got the car it had the nuts under the car with some excess bolt thread sticking out. Also, the car was lowered down a fair bit. The first time I drove it up onto the lift it stopped dead with quite a bang, like the whole power train suddenly seized up. Couldn't figure out what it was. The car still seemed OK so I backed up and took a bit of a run at it. A more sudden stop and a bigger bang. Finally saw that the protruding bolt thread caught on the joint between the ramp and the lift. It bent the 3/8" seat mounting bolts quite a bit. So it certainly is something to keep in mind with a lowered car.
