Results 1 to 9 of 9
Thread: Wheel Fitment to GEN 2 Body / Frame
    Jan 2019
    After rough setting the body on the frame I took some measurements to determine the proper backspacing for the wheels and tires.
    There is 6.5" from the inside of the wheel well to the rotor flange.
    There is 6.5" from the frame (shock lower support) to the rotor flange.
    So looking at the FFR recommendation for 6" backspacing seems to be incorrect at there will be additional 0.5-1" of tire width that has to be added to the backspacing.
    Currently I'm planning on running 20x10" 5.5" backspacing with a 0.5" spacer (if necessary), with a 295/25-20 this will result in a tire width of 11.6" and a tire height of 25.8"
    11.6" on a 10" rim will result in 0.8" on either side of the rim.
    5.5+0.8 = 6.3 - 0.5 (spacer) = 5.8"
    This should give me 0.7" clearance to wheel well and frame
    Sep 2019
    Almost. A 10" wheel is actually 11" wide overall. 10" inside, bead to bead, with 1/2" flanges. Backspacing is measured to the outside of that flange, so your tire should only overhang the the wheel by 0.3" per side.
    Jan 2019
    Quote Originally Posted by DoBoy View Post
    Thanks. I was unaware of that detail. So the 6" backspacing may be close. I bought the 5.5" backspaced wheels. should give me enough clearance and maybe without the spacers.
    Fatties. Hope this helps. (28x12 5" bs)
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
    Jun 2018
    North Vancouver, BC, Canada
    The FFR max recommendations in the manual are bang on. You can go max 6" backspace on the rears. Here's a helpful diagram for what DoBoy was mentioning above...
    Gen 1 '33 Hot Rod #1104
  6. Thanks RoadRacer thanked for this post
    May 2018
    Pinckney, MI
    I added a 1/2 spacer and all is good even room for a little more width on the outside.
    - Peterh226 #1134
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    Quote Originally Posted by sethmark View Post
    Can you still fit a (FFR) fender over that size tyre?
    thnx
    Robert
  9. #8
    Quote Originally Posted by j33ptj View Post
    thnx
    Robert
    From a distance.
    Titled 2-28-20
    MkI.IV 2643k
  10. #9
    I take that as a no,....
