During the assembly of your car, what was the point where you said: "After this, I won't dread anything more— this is the last thing I can completely f' up and cost me a lot of time or money to fix"? For me it was the front windshield. Seems like pretty much everything after this is "undoable". Well, I can finally say that I've reached the point of feeling no more impending doom! And it feels GOOD!
After trying unsuccessfully to find a windshield installer, I decided to try it myself— figured hey, I can build a car, I can probably install a windshield, right? With the help of a couple of brave neighbors and a healthy dose of whiskey to lure them and to provide some much needed liquid courage, we accomplished it over the weekend!
(Pardon the paint. Still not done with the cut and buff)
I'm really tickled with how it turned out. Other than a couple places with a little excess adhesive squished out on the inside bottom (nothing really noticeable, and certainly better than not enough), I can't say I would change much. I don't think a professional could have done any better— maybe just quicker. A few things I learned:
1. Despite the masking tape doing an excellent job, there were a couple of small places where the glass primer bled on the glass and (gasp) on the car paint as well. I about had a heart attack because I thought it would be impossible to remove it (especially from the paint). But I found it's super easy to remove with a razor blade on the window, and I was able to remove it from the paint with pure ethanol (I used reagent grade 100% ethanol, but I'm sure isopropyl/rubbing alcohol would do the same). The alcohol easily removed the primer without any noticeable change to the clearcoat. If you're curious, I used 3m primer and adhesive.
2. Everything I read seemed to say that wool daubers were the go-to choice for applying the primer, but I found that 1" chiseled foam paint brushes from the hardware store were by far the best. Don't be afraid to put on the primer quite thick and wet— it has the consistency of ink and it takes quite a bit to get it to cover well. Don't stress if it looks like a horrible butchered paint job on the back-side of the glass— better to lay it on thick and clumpy than miss any spots. As long as your glass is nice and clean, the side that matters will look absolutely beautiful. Also, don't worry about getting complete coverage on the first pass, it will take a couple of coats (with a little drying time between) to fill in all the spots.
3. I bought a couple of Harbor Freight suction cups, and my experience would say, don't bother. The window is curved so much that it was nearly impossible to get them to attach, and when I did, I didn't trust them. Because the window is so curved, as long as you make good alignment marks, it's pretty easy to set it down by hand on the center of the bottom edge, and then lean it back into place.
4. An electric caulking gun would have been really nice. I was actually able to lay a nice bead down by hand, but that wasn't the problem— it took nearly all my strength (and I'm a big guy) to squeeze the adhesive out continually. I don't know if maybe I didn't puncture the tube well enough (I thought I did), or maybe the weather being a little on the cooler side made it more viscous, or maybe the tube was bent or defective— whatever it was, I could barely finish the entire bead without crying uncle. My hands and fingers were shaking the whole time and nearly useless afterwards. And keep in mind, this was with the applicator tip being cut quite large with the V-shape on the side like pros recommend.
4. If you get any adhesive anywhere you don't want, a trick I learned a few years ago with acrylic adhesive is that it can be wiped off very easily with WD40. Otherwise if you try to wipe it dry it just turns into an impossible to remove smear.
5. I decided to go sans border weather stripping— I just like the look better. The window seems to fit very nicely and symmetrically enough. It was difficult to get the inset exactly the same from top-to-bottom, but at least it's symmetrical from side-to-side. I'm a pretty harsh judge and I'm happy with it.
6. As inspired by edwardb's build, using some lumber wrapped in towels and some ratchet straps is essential to getting the sides of the windows to seat and lay down properly.
Anyway, I'm really happy and excited to get past this! Hopefully this means some graduation pictures will be coming soon...
