Coupe Rear Brake Rotor contacting Caliper
Another question, on my first day of posting... I read a lot of threads about how to shim the rear caliper so that it will be centered on the rotor... but I have the opposite problem, it looks like the rotor is contacting the inside of the caliper. As if I need to shim the rotor out or find a way to move the rear caliper inward, which wouldn't appear to be easy. I have the 11.65 rear brakes from the complete kit along w/the Moser rear axle. Photos below. I can turn the wheel by hand, so it's not really tight against the caliper, but I definitely think it's making contact, and it's not centered on the rotor. Thanks! Emerson
I can't tell from the pictures ... are the pads installed? The portion of the caliper that slides on the pins should center with the pads.
Thanks for responding so quickly. Here are a couple more pics, trying to show where the rotor is touching the caliper. I have the pads in, but the inside portion of the caliper is fixed and doesn't move (the monkey arm thing slides in and out, I believe). Thanks!
Used a couple of washers/spacers in between the caliper mounting bracket and the axle flange. There are usually a few in the brake hardware for the purpose of centering the rotor in the brake caliper bracket.
thanks for the suggestion. Just tried that and it worked well. now it's more centered and not touching the actual caliper on either side. Thanks!
