Results 1 to 19 of 19
Thread: Whats the best way to insulate your your engine bay?
    Senior Member LuckyWinner's Avatar
    Fort Huachuca, Sierra Vista, AZ
    Been looking at heat shields that I could put on the firewall and on footbox where the headers are. Cant really find anything that would work and look good. Just thought it would be nice to try to stop the heat before it got to the aluminum. Then still use a insulation under the carpet. Any thoughts? I was thinking about stand-off plate out of stainless (a good thermal insulator compared to steel and aluminum), maybe 3/8" off the foot box.
    Owner MK4 7642RD, 393 stroker, Gordon Levy Super Alloy T5, HDX Clutch, Moser 3.31 3-link with disc brakes, 17" Bullit wheels, NT05's, Seat heaters donated by WarmSeats.com, door panels donated by Herbs Door panels.
    Hey Luckywinner,
    Here is a build site that shows heat sheilds like you are describing but out of alum. I'm sure you could fab them from SS. I think "dallas" has templates for them. It's a real nice build with a flip front end. I think you were on that thread about body work.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's.
    Build blog: www.myersfamilyffrbuild.blogspot.com
    I will be doing pics pretty soon to show what I am doing on the other side of the alum. See you later, WEK.
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    All I have is just the insulation under the carpet and there is no appreciable heat coming through.
    I have no insulation anywhere (aluminum or under carpet) and I don't have any noticeable problems w/ heat.
    Too many to count
    MKIII #5835 Someday I Suppose's Avatar
    Stanhope, NJ
    Insulated on the driver side as well here. The biggest issue I had with heat was what came around the foot boxes before I got some copper pipe insulation and stuck it up between the body and the sides of the footbox. :-)
    MKIII #3835 IRS, Anderson Performance 408 Levy T-5 Trans, Team III Wheels
    Paint completed November 2010, passed NJ State Safety Inspection June 21st, Tagged and First Drive 7/1/2011
    Quote Originally Posted by efnfast View Post
    Well yeah, but you live up there at the north pole where penguins in the road are a bigger problem than heat in the cockpit
    Senior Member cobrajj's Avatar
    Murrieta, Ca
    I covered the engine bay and footbox aluminum panels with Thermo Tec reflecting insulation then mounted 6" x 12"SS sheets w/ 3/8" spacers to provide an air gap. Positioned the panels next to where the headers run near the footboxes. Used 3/16" EZ Cool insulation under the carpeting. Easier to do before the engine goes in.
    Mk3.1 Complete kit #6846 Delv. 12/20/08-- Finished 2/11/11, 89 302 EFI,T-5, 3-Link, 17" Halibrands, Nitto 555 245-315 tires, widened drivers footbox w/ dead pedal, extended passengers footbox,Sapphire Blue Met & Wimbledon White stripes,radiator stone guard shield, Build blog http://jimsffrcobrabuild.blogspot.com/
    Colorado Springs
    I painted on Lizard Skin under the carpeting. I also have an air vent in the upper portion of the elephant ears. Between those two simple things, heat in the foot box is just not an issue. And it can get pretty darned hot around here; road surface temps of 145* are not uncommon.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Junior Member PhoneGUy's Avatar
    Has anyone used the koolmat product? I have read their marketing material and it looks like this is one of the best solutions for heat and noise. It also appears to be fairly dense in thickness so I don't think it will take up any much needed foot room in the foot box's.
    FFR7469 MKIV 15th Anniversary Edition
    Shubenacadie NS.
    What about fabricating fiberglass or kevlar panels the shape of the aluminum? I saw a 2011 Hemi Challenger that used kevlar tubing in the intake system to prevent heat transfer to the intake air. The same principle could be used here. I've seen a few dashes and tranny tunnels etc covered in it. Same idea, pretty cool look on the inside too. A spacer and rivets would hold it in place. A REALLY crafty person could probably fab up an insert that slips in in one or a few pieces for a nice clean look. Very little heat transfer. They're light weight and could be painted to match, contrast or accentuate the engine bay or painted a chrome, polished aluminum or copper colour.
    Daniel
    Junior Member Snakely's Avatar
    Auburn, IN
    Is Kevlar similar to sheets of Carbon Fiber? (in its heat distribution properties that is)
    I bought a piece of aluminum, measured, cut and bent it to use at the front of the footbox. Using screws and nuts and aluminum tubing for spacers, I mounted it so that it not only added a heat deflector for my feet, but my rear brake line as well. The panel also runs under the front part of the foot box floor, back to the cross frame, as added protection from road debris. Inexpensive, and a very simple mod to do.
    Shubenacadie NS.
    Snakely, I don't know. I do know they used it in the Challenger so the engine bay heat wouldn't be transmitted to the intake air as it passed through a metal hose. If it doesn't transmit heat and isn't ruined by intense heat, I see no reason why it couldn't be used. Fiberglass sheets, kevlar or carbon fiber sheets could be used I would imagine. Unless there's an issue with the heat. The body, hood etc is already fiberglass though so it couldn't be that big of an issue. Just make up some fiberglass panels using fiberglass cloth, epoxy, hardener and a sheet of glass for a smooth surface.
    I know from experience that Kevlar (sail material) has always been expensive as well as carbon fiber. I believe the dense rubber alum backed materials for heat/sound dampening are far more economical and easy to apply. Stick it and forget it! The stuff I used sticks to every thing including skin.
    I really like the SS panels AC Bill and using for a dual purpose was clever. Thanks for the ideas. WEK.
    Shubenacadie NS.
    True they are expensive but fiberglass isn't all that expensive in the grand scheme of things. There are, as I mentioned a number of roadsters with Carbon fiber dash etc so it's doeable I think. If that's what you're after. Not sure what I'd do to keep heat down, plumb your AC to the engine compartment!
    Senior Member BigLeo69's Avatar
    st. louis, MO
    got plenty of pics in my garage and in my profile album on ffcars, i would post them here but i seem to always have difficulty doing it, so i give up.
    i used the kevlar on the outer footbox and sandwiched aluminum 1/8" on the outer shell, i also cut my drivers up and modified it.
    Mk 3.1 #6945
    Silver Supporting Vendor Cameron Autosports's Avatar
    Agua Dulce, CA
    All you need is Dynamat Extreme inside all the foot boxes, behind the firewall, and on the tunnel. That will keep all the heat out. I do all of the passenger compartment including the rear bulkhead which keeps down all the noise and heat. It will cost about $450.00 to do all this, but I wouldn't build a car without it.
    #5560 All New Build MkIII IRS, 8.8 Torsen, Koni's, 427Stroker, Tremac TKO600, Fuel Cell, Pin Drive, Hugger Orange/White, SB100 • www.photobucket.com/albums/pp333/n1722t
    Cameron Autosports, LLC.
    West Coast Builder and Restorer of Award Winning Carswww.cameronautosports.com
    Winner: FFR Huntington Beach 2011 BEST OF SHOW • Winner: AHA Pomona, Ca 2011 BEST OF SHOW, BEST ENGINE, 1st Place Cobra Class $50K and 1st Place Cobra Class $30-$50K.
    Senior Member dallas_'s Avatar
    Dallas, TX
    Yeah, Alex, but you have those super duper ceramic headers that don't heat up, so you don't count.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Junior Member timp2's Avatar
    Traverse City, MI
    I used the Koolmat roadster kit from Breeze # 35322, inside under the carpet and #35314, also from breeze in areas in close proximity to the headers on the outside of the footboxes. Below is a copy of the ad in Breeze's online catalog
    If you have already installed your carpeting but have found you need to reduce the temperature of your foot boxes or transmission tunnel, this is the product for you. This product is made of 3 layers. Facing the heat source is a diamond embossed 10ml thick aluminum. This is designed to reflect radiant heat. A bonded 3/16" thick layer of high density fiberglass insulation comes next to protect against conductive heat. The third layer is pressure sensitive adhesive for easy installation. This is a 42" by 48" rectangle (14 square feet) of material that is shipped rolled up. You make your own patterns to cover the area desired and cut with scissors or a sharp blade.
    FFR MK III #6055
