Page 1 of 12 12311 ... LastLast
Results 1 to 40 of 470
Thread: Factory Five GTM Supercar, fastthings video build log
    Hi everyone,
    I'm Gene. I have started a video build log. I am a couple weeks into it, here we go.
    http://youtu.be/qQLWQK9jBYk
    http://youtu.be/50bmdsrIfBA
    Let me know if I am missing something, please.
    And here is part 3.
    http://youtu.be/_nlSySq84YM
    Senior Member VD2021's Avatar
    Central, FL
    Gene,
    This is what I'll be using on my hatch. I'll use it for mock up and reinstall for my final seal.
    McMaster Carr. 1120A311 16 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 3/16" Edge, 3/8" Bulb Width .
    R/s
    Vidal
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Quote Originally Posted by VD2021 View Post
    Gene,
    Ya, I could not find in the manual what seal they want us to use. Regardless, that one fits the bill. I'll go with that also. If I find that I robbed a part that I may need later I will get more.
    Just checked out your update...Thanks!
    Later....
    Quote Originally Posted by LeRoy View Post
    Later....
    Yep, here is #4, ruff fit the hood.
    http://youtu.be/Tx18C0T_BQI
    Central, FL
    Gene,
    Another nice video. Just wanted to point out a few items I am seeing right now with my hood. I am still working it to a nice happy median. You may have addressed these, but just incase.
    1. There needs to be enough space for the wiper to be mounted and operate. Unless you're not running one.
    2. The rise of the upper radiator hose elbow needs clearance as to not have the hood causing any unnecessary stress. Just means the front needs to be adjusted higher.
    R/s
    Vidal
    Gene,
    Oh. nice tips, thank you.
    I am doing the door now, and want to apply power to the window motor. Shouldn't I be able to put power to the motor, one way or anather to make it go up and down?
    Central, FL
    Quote Originally Posted by fastthings View Post
    If you're asking. 12v DC applied to the terminals and just reverse it for the opposite direction. If you have a 12v battery pack from a battery powered tool its very convenient. A 9.6v hobby battery pack will work too.
    I sent you a PM.
    R/s
    Vidal
    Mornig guy's. I got passenger door news.
    http://youtu.be/xjqXvareM5A
    Holly crap, fitting the door glass is tough. I feel bad for guys paying someone to do this stuff, lots of back and forth stuff. It will be interesting to see haw quik the other door goes, after doing one for the first time.
    http://youtu.be/yxwccUtGzX4
    http://youtu.be/M4BmIjb6wnk
    Working window. Glad to get that far, still a ton af work to do on the door. I'm looking for new seals for the door and window, same design but thicker, any ideas?
    Catonsville, Maryland
    Get a bottle of Jack
    Central, FL
    My Nemesis............
    R/s
    Vidal
    While doing a search for seals on the forum, I noticed that I took on the tough side first, huh. I read lots of threads dealing with the window, lots of frustrations. I was able to get it done, as intended by FFR.
    Anyway, I did not find a good source of seals to choose from, anyone have ideas, without the bottle of Jack, I like a blended whiskey.
    Central, FL
    McMaster has a huge selection of seals. Though I have not seen any with felt or flock.
    Did you do the track on the aft vertical? I like the potential of more stability and better sealing with the glass in the closed position. However it will not affect the glass until it’s almost in the fully closed position. I am planning to use the SPW UC-1 and CRL 10G96 if I add the track. Did you find a salvage alternative in your search?
    R/s
    Vidal
    Don't think you're gettting off easy by doing the right side first....Just wait till you get to the left side door
    Ok so the bottle of Jack is not for you, have you look at the C-5 door and window seals??? The GTM has it's DNA just wondering if the Vette stuff could be modified to work.
    Good Stuff Gene....
    When you get this done I'll supply a bottle of Mason County drip or Crown.
    Quote Originally Posted by Presto51 View Post
    Is it the driver side that gives everyone troubles?
    Central, FL
    Both require hours and hours of work. The Driver's side may take you a few less, but chances are you will not say it was easier. The doors are different. Driver's is thicker and the frames are not the same.........
    R/s
    Vidal
    My question would be is why is the doors so time consuming. Would be nice if someone from FFR would chime in and give a reason why there are so many modifications to get the windows/latches and most importantly the seals to work. I'm fortunate to have a dad that is creative with fiberglass and will help rework these doors. Maybe FFr should have made their own window lift mechanism instead of using the corvettes. Did they not have these difficulties when assembling/test fitting before production began?
    I am very thankful for the crew here on the forum helping out with video's like this and advice to what to do and what not to do. This will definitely help when my time arrives to tackle these doors.
    Team Bouffard
    GenII #369 - SOLD
    1968 Camaro - work in progress
    Central, FL
    Quote Originally Posted by RF RIDER View Post
    Your time is consumed solving and fixing issues. It takes hours initially just to get the door frame initially fitted to the body. As you progress through the steps you continually run into issues that you have to address. Some require you to go through most of the initial steps again. Ultimately I believe the majority of the time is spent trying to get a decent seal if you stay frame-less or redoing the donor tracks and creating a full frame if you go that route.
    R/s
    Vidal
    Well, it's no joke. I'm still not done with that door. I now am going to use partial frame up the post on the door.
    Still have to work out a seal for the door. I'll get it, and it will be good.
    RF RIDER, I think they havn't done it because it's not easy.
    Ya know, I have no complaints to FFR. The kit is what it is. Sure ya got to work at it, but the reward must be immense. For me the first time I saw one I was hooked. If you want one, put your head down, and plow threw it, and smile. That's what I'm doing. And yes, I have been reading the other for a year or so, and this this forum since it's start, it makes it nice for all, all our cars end up being better than not.
    None of us are as smart as all of us, right.
    Well I got the door sitting in much better form. Still need to take it back apart and paint the internals. Then all I have left is to get it to seal without wanting to bind the door while it shuts.
    http://youtu.be/Y9_3FkCdzpY
    http://youtu.be/XKKWhL4wNXE
    I got the passenger door 80% done, now time to do it again on the other side. Looking forward to it only taking half the time, now that I know what I'm after.
    Well after a little distraction called life I have the drivers door done now. Moveing on to the hood.
    http://youtu.be/5BhFUL_72jM
    Video 11, bodywork on the hood.
    http://youtu.be/_fYkOqT0efk
    Gene very nice work on the hood.
    Coffee came out my nose when I laugh at the PIA comment at the end though, now I have to change my shirt
    That's funny.
    Senior Member Kempo's Avatar
    Cabo Rojo,PR. USA
    I really like seeing this videos. They are full of useful information. Thanks for sharing all those years of knowledge with us in those very detailed videos.
    H
    GenII GTM #354
    Delivered (02/09/11)
    Quote Originally Posted by Kempo View Post
    H
    Hey Kempo, I have the ISIS touch also, have not even got it out of the box yet. I've been thinking of what to have on a regular switch, or just run from the touch. What are you doing?
    LCD Gauges's Avatar
    Toronto, Ontario
    Same as Kempo:
    Thank you for posting these detailed videos of your progress and sharing your techniques. I'm glad you reached the door stage before I did, and that I can steal some tips from you!
    These windows are giving me nightmares just reading about the difficulties. I've often thought about alternatives , like some sort of fixed window that can be removed like a
    t-top and stored in the car when not needed...
    ummm, alright...it's not the greatest Idea, but it would probably be easier than spending two weeks on one door, right?
    Cabo Rojo,PR. USA
    I will not be using a regular switch with a key. The inTouch requires that you splice the yellow wire (IIRC) on its harness to add a switch to turn off the screen. My plan is to hide that switch somewhere in the car. That hidden switch and the 6 digit code in the system should be safe enough for a car I won't be leaving parked just anywhere.
    GenII GTM #354
    Great videos: When done you should make a cd of all of them and sell the cd. I bet a lot of new GTM buyers wood buy it. Alot of old ones all so. I know I would. I wish I had your tallent.
    Leonard
    Quote Originally Posted by lrt1941 View Post
    Leonard
    Wow,thanks. It's all on youtube, for free. I guess it would be nice on cd. That's why i put it on youtube though is becaue I don't have to store it forever, and youtube will.
    Central, FL
    Gene,
    Outstanding. This is the most informing video log yet. You are talented. What's next?
    R/s
    Vidal
    http://youtu.be/UwNcN6fVVWw
    Hood pretty much ready for primer. Time to work on the hatch.
    Cape Cod
    "thats a good place for that" too funny.
    Watched to whole thing, you are a craftsman!
    Noticed a few things slightly off, the LS2 first came in the 05 Vette and Shane lives in Iowa.
    Please keep the videos coming, very informative.
    Ya I couldn't remember the year, now that you say that, I think it's out of a 06. It's been a year. And I guess I never knew where Shane was, another bad guess.
    Thanks Kalstar
