Thanks Thanks:  6
Likes Likes:  86
Page 4 of 4 FirstFirst ... 234
Results 121 to 156 of 156
Thread: Saved a Gen 1 GTM : DAY 65 Build Graduated 3/17/2022
  1. #121
    The dash always interferes with the doors. We cut down both sides of the dash on every GTM we build, and a lot of times it's tough to get enough cut off of the dash to keep it from crashing into the doors. On many cars, we've had to both cut the dash pods back as far as we can (without getting into the vent opening) AND modify the door panels so that the doors will close.
    Shane Vacek
    www.vraptorspeedworks.com
  2. #122
    Huntsville, Al
    shane - yes that's looking like what I will need to do - My Gen 2 wasn't bad - but geez this one is pretty bad on the pass side - I have it cut it back on the dash side some - I will have to go back and get a little more aggressive - I am not quite to the vent yet so I have a little more room to go. I got the door to close without the door card now - so I am close... I decided to take a break since frustration and having a cut off wheel in my hand always ends badly
  3. #123
    Falmouth, MA
    Frustrated and having the cutoff wheel in hand -- yup leads to disasterous results that I can attest too!
  4. #124
    Huntsville, Al
    Well only worked on it a little during the week... I gave myself about an hour each day to go out and see if I could get the passenger door figured out - if I couldn't do it or see it after an hour I just went inside.... I saw something on Wednesday - checked it out of Thursday - and low and behold on Friday... I got the door to shut all the way with the door card installed!! I also got my steering wheel in minus the quick release hub - but threw it on there anyway I really like the color match with all the other blue
    So I am going to call this Day 49
    FU Door! - I ended cutting about 3/4 of in off the outboard end of the dash ... and about an inch on the inboard bottom... door car is in (taped in position)...
    Driver's side door went on without issues
    Steering wheel
  5. #125
    Huntsville, Al
    Day 49 continued today with the Wing and diffuser - came out pretty good I think.
  6. Likes jbs72697 liked this post
  7. #126
    Looks like it's coming together nicely! Glad you got the door/dash figured out.....always one of my least favorite things to do....cut the end of the dash off and then try to make the upholstery look nice.....
    Shane Vacek
  8. #127
    Huntsville, Al
    Thanks Shane - yeah I was very depressed when I needed to cut the freshly covered dash But it's part of the process. Thanks for all the parts BTW...
  9. #128
    Huntsville, Al
    Well - the build has been dragging on a bit - for me anyway - we are in the part of the build that there are like 1000 - 10 minute tasks that need to get done - garage is a bit cold - so rather than step away from it - I blew it off gave it a quick wipe down and fired it up and pushed it outside to finally see it outside in the sun and from farther away than 5 feet - must have been good cause I took it for a drive around the block after.... I fell better now - I will get back at it tomorrow - have to wire up the side mirrors - i figure the motors work - I might as well take 5 minutes and wire them up... then I will start closing up the passenger side door and get the speakers in - just have to knock the list down - seems like we are getting closer every day. Anyway the blue really pops in the sun - keep in mind the paint isn't final buffed and it is still somewhat dusty... but geez - it's a loud blue!
  10. Likes beeman, jbs72697, GoDadGo liked this post
  11. #129
    "The I.E." SoCal
    Said it over on fb already Erik, but that looks fantastic!
    __________________________
  12. #130
    That blue really comes to life in the sun!
    Mar 2020
    Braintree MA
    I have an 818S that I’ll be building. I thought I had settled on painting it red, but after seeing this blue now I’m rethinking it
    Looks awesome!!
  14. #132
    Looks Super!
    16+ FFR kits and counting!
  15. #133
    Huntsville, Al
    Closing in on the finish line - still a few small things to finish up - the list just is sooooo long on all these finishing touches.... sat in the car and chilled a bit...
  16. Likes jbs72697, Edgeman liked this post
  17. #134
    Falmouth, MA
    Looking great! When I built my GTM back in 2006 (?) #82 it seemed like the punchlist went on forever. The door issue you just completed was a scary process although I don't remember mine being quite as involved but there was an issue with getting the window to seal at the front. If I remember I built a small triangle onto the door to make it work. Power windows were another big headache. I'm curious in what you have done with the cooling tubes running through the tunnel. I heavily insulated the tubes but it was still unbearable in the cockpit. I removed the bottom closure panel and that helped a lot. I always thought if I built another GTM I would look at running them through the rocker panel/door sill similar to some Porsches.
  18. #135
    San Diego
    Quote Originally Posted by cob427sc View Post
    Exactly what we did on the FFR PDG GTM race car. Dropped the interior temperature considerably.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  19. #136
    Falmouth, MA
    Before removing the lower tunnel pan you could not keep your hand on the tunnel. It cooled down considerably with the pan removed but still stayed warm and transferred a lot of heat into the cabin. I really think, especially for a street car, insulating and running them through the rocker would be the way to go. I thought about doing this then filling the rocker with foam.
  20. #137
    Huntsville, Al
    Well - 65 days of actual wrench time - I gonna call it done ... not graduated though as I am still waiting for the VIN process to complete so that I can get plates and insurance. I still have to put door seals in around the perimeter of the forward, bottom and rear of doors... I will need to drive it around a bit to do a full shakedown to make sure the fit and finish is good then put up for sale.... I think. All I have done thus far is drive up and down the street - seems good thus far.... Anyway - here is the 3-piece Suit (mostly buffed out) next to the Combat Gear....
  21. Likes beeman liked this post
  22. #138
    Huntsville, Al
  23. Likes Edgeman liked this post
  24. #139
    Huntsville, Al
  25. Likes FF33rod, Jkviper, Geoff H, JohnnyB liked this post
  26. #140
    Jun 2018
    North Vancouver, BC, Canada
    Looks fabulous Eric, a lot of work in that puppy!
    Gen 1 '33 Hot Rod #1104
  27. Likes Erik W. Treves liked this post
  28. #141
    Looks great Erik. Now that's BLUE.
  29. Likes Erik W. Treves liked this post
  30. #142
    Your usual super job! Well done.
  31. Likes Erik W. Treves liked this post
  32. #143
    Senior Member beeman's Avatar
    Indiana
    Congrats, beautiful car.
    GTM #304 LPE 525hp LS3
  33. Likes Erik W. Treves liked this post
  34. #144
    Very Nice!! How did you attach the plexi to the hatch opening?
    Shane Vacek
  35. #145
    Huntsville, Al
    Thanks Shane (and guys) -
    When we bonded your rear hatch piece we left the "lip" at the top where the glass would lay in; we left it open.... so the Lexan slips in there perfectly.... as you know the hatch has a natural "bow" to it... the Lexan being flat and a little flexible, I installed a metal clip on the bottom/rear edge which naturally "bowed" the Lexan up tight in the rear corners - the only thing left after that were the sides - I then scuffed the Lexan with 80 grit - 1 1/4 all around the perimeter and just used glass urethane (fast dry) and clamped it all for 24 hours.... seems like it's holding really well - but I havent had it at speed yet.... but it should be drawing it tighter at speed as it tries to "suck out"... If I need to post a pic of the bracket under the hatch I can certainly do that for the group for later reference if you think it would be useful?
  36. #146
    That all makes sense. Sounds like a great solution!
    Shane Vacek
  37. #147
    Huntsville, Al
    A non-build related up date but very important step to get on on the road: I was happy to see that my documentation was all approved! In-car video soon hopefully,
  38. #148
    mburger's Avatar
    Punta Gorda FL
    Been following your progress. It looks awesome! Another great build. Congrats!
    Mark
  39. #149
    Chino Valley, Arizona
    Par for course, another stunning build Erik! Love that blue...
  40. #150
    Huntsville, Al
    All done and done - now to go do some break-in miles before it goes up for sale.... so the wife says
  41. Likes WIS89, Shoeless, RR46 liked this post
  42. #151
    Great car Erik, and I enjoyed reading through this build thread. I am thinking the Stanceparts lift cups is going to be a must for my Gen2 as well. You switched out the front KONI blacks and replaced them with the yellows that can be inverted to work with the cups on the bottom, where they fit. Do you know the model of the yellow shock you used? That would be a starting point for me to find replacements for mine so I can do the same thing. I am sure others might like to go that route as well.
  43. #152
    San Diego
    I think I have 3 yellow shocks in the shop. Stripped down to just shock bodies, but left over from a build that went with after market shocks. $50 plus shipping if you want them.
    www.myraceshop.com
    GTM solution kits
  44. #153
    Thanks Crash. PM sent.
  45. #154
    Huntsville, Al
    Markm - The yellows came with the kit from FFR.
  46. #155
    Right. My mistake. I also have an idea for keeping crap out of the bottom mounted cup, but will post something after I prove it works.
  47. #156
    San Diego
    Quote Originally Posted by markm View Post
    Just for clarity, IIRC the early kits came with black Koni shocks, and then, at some point, FFR switched over to yellows. It is said the blacks can only be run in one direction, while the yellows can be run in either direction.
    www.myraceshop.com
    GTM solution kits
