Results 1 to 3 of 3
Thread: MK 3.1 Roadster, Granbury, TX
    Senior Member jkrueger's Avatar
    DFW, TX
    I have for sale a MK 3.1 Factory Five Roadster (chassis #6445). I bought the kit in 2008 and finished it in 2010. It is registered and titled in TX as a 2010 assembled, but also has on the title that it is a 1965 replica. It has 623 miles on it (as of 10/2011) and I am asking $29,500 for it. It was a donor build, but I rebuilt most of the donor parts (see below). I have all the receipts from the build. I am selling because I want to build a coupe now. Here are the details of the car.
    Note: When I say new or rebuilt, that means when I built the car.
    Engine:
    1989 Ford 302. It was rebuilt and bored .030” over when I bought the car and has 10k miles on the motor.
    New Edelbrock dual plane Performer RPM manifold
    New Edelbrock 600 cfm 4 barrel carb with electric choke, vacuum secondaries
    New Ford racing E303 cam
    New Ford racing X306 heads
    New Cobra valve covers
    New cam bearings, lifters, push rods, rocker arms
    New oil pump
    Stock headers
    Ceramic coated side pipes and J-pipes
    Clutch:
    - Re-surfaced flywheel
    New king cobra clutch, pressure plate, throw out bearing, and pilot bearing
    New clutch cable and Ford racing clutch adjuster
    Transmission:
    T-5 transmission rebuilt with Ford Racing part number# M-700-A
    Rear axle:
    8.8 solid axle with new Ford Racing 3.55 gears
    Rebuilt traction-Loc, new axle, pinion and carrier bearings
    Electrical:
    - Ron Francis chassis harness and fuse box
    Summit racing ignition control box with rev limiter
    Battery cut off switch
    Rear mounted FFmetal battery box
    180 degree automatic cooling fan switch with manual override
    Fuel system:
    Stock mustang tank
    External electric fuel pump
    Fuel pressure gauge on carburetor
    Chassis, Suspension, Brakes and wheels:
    - Black powder coated frame
    Koni coilovers
    Factory Five 3-link rear suspension with welded on top link arm
    Factory Five tubular front lower control arms
    5 lug hubs
    Manual front disc, rear drum brakes
    New rear brake spring rebuild kit
    New front brake pads and rear brake shoes
    Power steering
    -Team 3 aluminum 5 lug Halibrand wheels with replica knock off spinners. 15x8 front,
    15x10 rear.
    Goodyear Eagle GT 235/60/15 front 295/50/15 rear
    Body and exterior:
    Rolled cockpit edges and rolled wheel wells
    Feather fill primer, PPG DP90LF epoxy sealer, PPG Black base coat/clear coat paint
    Wet sanded and professionally buffed
    Entire under body has truck bed liner coating
    Dual chrome roll bar with trim rings (*small rash in chrome on passenger side*)
    Tangent blind roll bar kit
    Chrome front and rear quick jacks
    Visors and wind wings
    Factory five hood hinge kit
    Replica Parts trunk support kit
    Factory five wiper kit
    Interior:
    Low back vinyl seats with Breeze angled adjustable seat mounts
    Sound deadening and heat shielding in entire cockpit
    Door vinyl side pockets
    Vintage gauges
    Fuel pump and fuel tank access plates in trunk
    More pictures of the build can be found here:
    FFR Roadster
    If you want more detailed pictures or more information email me at: [email protected]
    JC
    DFW, TX
    Here are a couple of more pictures:
    DFW, TX
    Sold.
