As anybody had this problem? One side the parts that bolts to the hood is right on the other side is 3/4” away
Spent a lot of time here; removed shroud (cowl) from grill; made accessing hinge adjustments much easier, ended up with a reasonable fit, will need some glass work to get it where I am satisfied (used a spacer on the radiator bracket to for the hood to bottom on while adjusting)
