Thanks Thanks:  2
Likes Likes:  2
Results 1 to 3 of 3
Thread: QA1 shock information needed
    Jan 2019
    I need to determine the correct part number for QA1-DA single adjustment shocks. They are for the rear axle on a Mark 3/ 4 link. I know the topic has been covered many, many times. But rarely does the actual part number builders used show up. I must move forward with this your response is greatly appreciated.
    Maricopa AZ
    There isn't a parts that is a direct bolt on. I sell QA1 kits, most double adjustable.
  3. Thanks BLUE KNIGHT thanked for this post
    Likes BLUE KNIGHT liked this post
    Seasoned Citizen NAZ's Avatar
    Don't waste your $$ on a single adjustable shock. Shocks control vertical tire speed in both directions and the damping needed is almost never the same in both directions. Get the double adjustable version -- they're good quality shocks for the money. And learn how to adjust them. I'm sure Gordon can help you select the right shocks and help you adjust them to fit your car's needs.
  5. Thanks BLUE KNIGHT thanked for this post
