02-10-2024, 08:59 AM
#921
RHK118 - Yes I am going to liner the wheel well panel pieces. I did all my prep/bodywork before the liner. To do the liner first might cause issues later IMO. Although I believe Paul did it that way without issues. Keep in mind that I built mine to the point where I could drive it for a season before completeing it.
02-27-2024, 03:00 PM
#922
Need some upholstery help!
During the past year my upholstery has delaminated. I used marine grade vinyl with foam padding and 3M 77 and 99 spray adhesive. The foam has sticked like gangbusters but the vinyl has pulled up. The part that has delaminated is a sticky gooey mess. I will need to redo it but I need to figure out what I did wrong first. Did I use the wrong vinyl? The wrong adhesive? Did I wait to long for the glue or not long enough? Should I have used a heat gun to soften the vinyl around the edges?
Any suggestions are welcome!!
02-27-2024, 05:11 PM
#923
I’ve never had luck with spray stuff. Anything two part or from a can is going to be better. Short of having a professional spray set up. Lot of different outdoor carpet adhesives like weldwood.
03-04-2024, 10:24 AM
#924
60 degrees at the end of Feb. in the northeast! Who would have thought??
Finished coating the underside of the body over the weekend in this great weather! Next step is to build a body buck for painting and mask off the undercaoting.
03-04-2024, 11:20 AM
#925
Any reason not to put it on the car and mask off? I think many have painted that way.
03-04-2024, 03:51 PM
#926
Originally Posted by
Kbl7td
My painter wanted to paint it off the chassis.
03-04-2024, 04:10 PM
#927
I love that you've tackled this yourself Scott. Looks great!
03-04-2024, 05:59 PM
#928
rhk118
I was going to paint it also but after discussions with my painter I decided to let him do it. My garage just isn't set up properly nor do I have the proper compressor, spray guns, etc.
03-05-2024, 09:51 AM
#929
yep. mine was painted off the chassis as well.
Doug
03-10-2024, 04:26 PM
#930
03-27-2024, 11:59 PM
#931
Started the process of getting the coupe painted. I did most of the bodywork and a member of the upstate cobra club, who lives near me, is doing the painting. Here is a link to the picture gallery.
https://photos.app.goo.gl/G5ZnxB5DFXBLcewr9
03-28-2024, 08:36 PM
#932
04-04-2024, 05:12 PM
#933
A coat of primer/sealer was applied and all of the pin holes were filled with a glaze filler and sanded. The high build primer has been applied.
04-04-2024, 08:19 PM
#934
Not a waxer
Ah, Evercoat Optix. Dries pink, sands to gray. I used it once.
04-04-2024, 08:32 PM
#935
Jeff Kleiner
My 18 year old daughter "voted" to leave it that color..... OVER-RULED!
Scott
04-04-2024, 08:39 PM
#936
I like it. The Mary Kay type 65!
04-04-2024, 10:18 PM
#937
Rsnake
You know about Mary Kay??? My "X" was a Mary Kay Director. I enjoyed a couple of trips to Dallas for their convention.
Scott
04-04-2024, 10:23 PM
#938
All I know about Mary Kay is they had pink Cadillacs that looked identical in color to your car.
Great job on the build.
04-05-2024, 09:52 AM
#939
Rsnake
Your correct. When a Director build her team to a certian level they were given a "company car". There were different levels of cars available with the top level being the pink caddy.
Thanks for the positive feedback on my build. Have watched your videos and would love to see your some day.
04-05-2024, 10:15 AM
#940
Not a waxer
When I used it I posted some pics without explanation and figured it would get some reactions. The comments from forum members did not disappoint
https://thefactoryfiveforum.com/show...light=evercoat
It's looking really good Scott!
04-05-2024, 12:20 PM
#941
Scott, a type 65 meetup in the middle of the country, i like it. Kansas City for some BBQ?
Let's start planning
04-05-2024, 12:30 PM
#942
Rsnake
That would be wild!!
04-08-2024, 05:24 PM
#943
While the body is off being painted I have been working on a few things on the chassis.
I was not happy with the battery I had. My first one ended up with a bad cell halfway thru the season last year. I replaced it with the same and just was not happy with it. Cold starts were ok but hot starts scared me. Others have used this same battery without issue but I was not happy. I chose to replace it with a much larger battery which required a new battery box also. This battery has 1150 CCA so it should do a lot better with hot starting.
I also decided to add remote battery terminals. Will make it a lot easier if I need to jump.
04-13-2024, 05:24 PM
#944
Spent the day with my painter today. Here's a teaser of our accomplishments....
04-13-2024, 09:07 PM
#945
04-13-2024, 09:51 PM
#946
Wow! Looks great. Can't go wrong with a red sports car
04-13-2024, 10:04 PM
#947
Beautiful. I love red with white stripes!
04-13-2024, 10:58 PM
#948
JimStone
Thanks Jim!
04-13-2024, 11:01 PM
#949
Rsnake
Thank you Sir! Appreciate the support. Coming out better than I had imagined.
04-13-2024, 11:30 PM
#950
Did someone say red? I've heard of using that color. Looks great.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
04-14-2024, 01:13 AM
#951
edwardb
Sarcasm noted.
I saw a new Tahoe today with one of the most awesome medium dark metallic reds I have every seen. I will being trying to replicate that color on my coupe. I used House of Kolor products and their semi-candy Apple Red is amazing by itself but it is a bit lighter in color. I think painting the apple red over a black or dark red base should get me close.
04-14-2024, 09:41 AM
#952
edwardb
Ya I got that inspiration from somewhere?? Pleased with how the stripes came out.
04-14-2024, 09:42 AM
#953
Alan_C
Sarcasm noted.
That should look awesome.
04-14-2024, 09:44 AM
#954
04-14-2024, 11:03 AM
#955
Skuzzy
Looks great!
Thanks Skuzzy!
04-15-2024, 03:07 PM
#956
04-15-2024, 03:09 PM
#957
Not a waxer
Looking great Scott!
04-15-2024, 03:10 PM
#958
Nice work! That wasn't so hard, was it?
Build Thread and
Video.
Build Thread and
Video
04-15-2024, 04:01 PM
#959
Jeff Kleiner
Thanks Jeff!
04-15-2024, 04:08 PM
#960
edwardb
I was really concerned about doing this and have been putting it off. Because I will be getting the painted body back in a week or two I needed to man up and give it a shot but as you said it wasn't so hard at all! Was easier than anticipated and came out better than I expected. CI tomorrow and then on to the other project I have not been looking forward to .... carpet!
