I've been driving the car each summer for 5 yrs. Last fall the signals stopped working.
Now I am getting it on the road again and need to figure it out.
If I am reading it right, the wiring diagram for 2002 Donor below shows:
FB1-FB4 powers the LgB wire to the LH turn signal switch.
FB2 to FB5 powers the BG wire to the RH turn signal switch.
When you have ignition on, and you move the turn signal lever, it goes through the Turn signal/Hazard Module which grounds the circuit turning the light on?
I am showing no power on either wire for LgB or BG wires.
I checked fuses FB1 - FB5 and they are all OK.
Is there a relay or something powering the FB that could have failed?
Also, I checked the Hazard lights operation..... they work as they should.... flashing all 4 corners.
Stuck and wondering what it could be.......hope one of you guys can help.
Thanks.
