Front black KONI shocks
Check the other thread on the form. Front black koni shocks that comes with the kit. They will not work if put on wrong way up as manual call for. Took mine off and checked them out. You need the main body to the bottom and spring to top. Hope this will help others. I recommend checking other form before doing any thing, because I get thing messed up trying to explain them.
Leonard
Leonard,
sounds to me like you have done just fine.
Cheers
