Results 1 to 11 of 11
Thread: Is this Transmission workable?
    Oct 2022
    North Carolina
    Hi, I am starting!!
    I currently have a 5.0 engine from a 1999 Bronco at an engine builder to be balanced, blueprinted, heads, cam and crank done
    Should be 350ish HP.
    I am told that a repopped Mustang tranny will work.
    I found this as an example .. anyone got an opinion? (retorical I know)
    https://www.ebay.com/itm/28499756168...547309183ad2c8
    Thanks guys,
    Fred
    Dublin, OH
    not sure what the max torque is for a T5z. I have a T5z paired w/ my 289 HiPo and seems to work just fine. check out the new TKX trans. same size but stronger.
    Oct 2022
    North Carolina
    The T5z is rated for 330ftlbs and up to 430hp. The TKX 600 ftlbs. Overkill, but I am good with overkill. Waiting to hear from the engine guy.
    Thanks for the help!
    Southport, NC
    I am running a T-5 out of an '89 Mustang with engine calculated 350+ HP at the flywheel. Remember, the roadster is about 2300 lbs., a lot lighter than the Mustang, thus the transmission will not experience as much stress. I built both the engine and transmission (also added the upgraded Billet cluster support plate) and both are running great at 3600 miles. I'm happy with the combination, however, replacing internal transmission parts cost me about $1000. I also had to source the parts from several different sellers.
    George
    Maricopa AZ
    Yes.
    Oct 2022
    North Carolina
    Thanks guys!
    First of likely many questions. I also talked with a few Mustang guys local here. Likely going with the T5z.
    Cheers!!
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    If you want to have a straight up shifter handle in the proper location for an FIA car, you'll need to do the S10 modification, changing the tailshaft and a couple other small parts. The location of the shifter on that transmission is fine for the 427, but not the FIA.
    Rick
    Mk4 with Mr. Bruce FIA body, 331 w/ Speedmaster Stack Injection, Full Width Roll Bar with high brake lights by i.e.427, IRS, ABS, PS, PB, FAST FI, First start 3/30/20, First go-kart 7/5/20, paint by Ken Pike
    Oct 2022
    North Carolina
    Quote Originally Posted by EZ$ View Post
    Is that something one buys or makes? I did a bit of a search and not sure.
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Quote Originally Posted by egchewy79 View Post
    Reach out to Mike Forte, his TKXs are about the best price around.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
    Oct 2022
    North Carolina
    OK, I ordered the TKX, the mid shift kit, bell housing and a Moser rear end from Mike. Might as well do it right.
    He did bring up a potential issue .. I got an engine from a 99 Explorer, my builder said it had the GT40 heads and that he could work them instead of buying new ones as was planned however ... do the P heads from the explorer have issues with fitment with factory 5 j pipes or headers? Does anyone know?
    Thanks for all the help guys .. I am soooo stoked!
    May 2013
    OH,KY,WV tri-state area
    Quote Originally Posted by FredG View Post
    you will much happier with the TKX Looking at that ad fir that T5 it has 4cy turbo gear set. (4.03 first gear!!) THe 4 cy versions are not rated for the power of a 5.0 HO let alone 350HP
