Thanks Thanks:  8
Likes Likes:  170
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 81 to 120 of 208
Thread: # 1115 resurrection
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Ltfracing View Post
    Just wondering what wheels are on it,and what size tires,thank you
    Currently, It has Jegs rims, Fronts are 195/45-17 Rears are 295/50-15 but those are only temporary and what came with the car. They are being replaced with Schott Accelerators 18x9 285/40-18 & 20x11 315/35-20
  2. Thanks Ltfracing thanked for this post
    Likes Ltfracing liked this post
  3. #82
    Sep 2022
    Huntington, IN
    Chipping away at the "to do" list, A/C unit mounted
    20230301_190854 by F G, on Flickr
  4. Likes narly1, TxMike64, FF33rod liked this post
  5. #83
    Sep 2022
    Huntington, IN
    I bet I rearranged those bulkhead fittings more than a dozen times looking for what works the best.. I think i'm close. Waiting on the Comp manifold and a bracket for the drier before I can go any further.
    20230307_202222 by F G, on Flickr
    20230307_192433 by F G, on Flickr
  6. Likes FF33rod, JOP33 liked this post
  7. #84
    Oct 2019
    Erin, Ontario CANADA
    As we used to say back in the day looking "sano".
    Earl
    1st Speedstar in Canada 31 March 2023.
    Built by me 302 engine, AOD trans, 3.55 IRS.
  8. Likes Just 1 More liked this post
  9. #85
    Kingsland, TX
    I'm going to steal your pic to point out a question that I have.
    See the attached image: are the floorpans supposed to go on top of the bottom horizonal flange of the lower firewall pieces? (they're under in the image)
  10. #86
    Sep 2022
    Huntington, IN
    Great question, I do not know the answer. These were like this when I bought the unfinished kit
  11. #87
    Jun 2018
    North Vancouver, BC, Canada
    The firewall and footbox fronts install long before the floor pieces in both the Gen 1 and Gen 2 build manuals so they would end up under....
    Gen 1 '33 Hot Rod #1104
  12. Likes RoadRacer liked this post
  13. #88
    As Steve said.
  14. #89
    Jul 2020
    Spencer, MA
    Ditto. I had about 1/4" space between the floor and the footbox pieces. I jacked them up using a 2x4 and drilled the rivet holes. Then I gooped them with the marine adhesive, jacked them back up and 3/16 riveted them. 4 on each side.
  15. Thanks TxMike64 thanked for this post
    Likes FF33rod liked this post
  16. #90
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Mastertech5 View Post
    Dang, I better read that manual a little better. Mine came with the floor panel under the lip of the firewall so I assumed that was correct.
  17. #91
    Quote Originally Posted by Just 1 More View Post
    Yeah, just think of the joint, one is much harder to get water through. But since you'll caulk anyway, not a huge thing.
  18. Likes Just 1 More liked this post
  19. #92
    Sep 2022
    Huntington, IN
    This is as good as it's going to get. Adding in the heater valve and drier really boogered things up for me in the clean and neat look. Once the body is on and the lower front skirts, it should hide a lot of it. So this is it until I get another brainfart and change it. I'll clean up the sleeving with heatshrink once everything is crimped.
  20. Likes FF33rod liked this post
  21. #93
    Something to keep in mind - you are going to have to install the door striker mount bracket after the body goes on. It goes right behind where you have your hoses going thru the fire wall and the 2 carriage bolts install from the outside pointing in. Better figure out a technique for it now or you will be hating life a little later.
  22. Likes peterh226 liked this post
  23. #94
    Jun 2018
    Looks great, nice and tidy!
  24. Thanks Suasponte91685! thanked for this post
  25. #95
    Sep 2022
    Huntington, IN
    As I figured, the header and drier tried to occupy some of the same space so on to Revision # 43, Moved the drier to the firewall, got a 90 degree fitting to come directly off the bulkhead to the drier than a 135 degree fitting from the drier to the condenser hose. Still need to make a bracket to secure the drier to the firewall but that'll be the easy part.
    20230331_125021 by F G, on Flickr
    20230331_125038 by F G, on Flickr
  26. Likes FF33rod liked this post
  27. #96
    Jul 2020
    Spencer, MA
    You should keep the dryer sealed up with the plugs it comes with until your ready to assemble the whole system after getting you're hoses set. The dessicant in it will absorb any moisture in the air and become saturated, then it can't do it's job for your system charge. Mine came with a 2 piece bracket and hose clamps that can be used to mount in various places. When the system is charged, you watch the sight glass on the top of the dryer for bubbles. When they stop wait 5-10 seconds and then stop charging, it's full. It should be evacuated for an hour with an AC vacuum pump before charging. If your compressor comes with the PAG oil in it you should only add 1 more ounce to the system. R134a cans are available with PAG oil in it. 1 can of that and then straight R134a. If taking it to a shop then they "should" know, but remind the Tech because I'm sure they've never done one of these before. All the cars they work on have a label that tells them how much refrigerant and oil to put in the system.
  28. Thanks Just 1 More thanked for this post
  29. #97
    Sep 2022
    Huntington, IN
    100% agree with you and pretty much figure with as many times as i've had to open the drier to change mounting and hose orientation, A new one prior to charging probably wouldn't be a bad idea.
  30. #98
    Jul 2020
    Spencer, MA
    I added addition info to my post about charging your system.
  31. #99
    Sep 2022
    Huntington, IN
    Jul 2020
    Spencer, MA
    I hope the lifter is ok. Does your engine have roller rockers or flat tappet? I've seen the pushrod cup in the lifter flip out in situations like that. Good luck!
  33. #101
    Sep 2022
    Huntington, IN
    Hyd Roller, and upon further inspection after pulling the heads off.. That valve is stuck open, that rocker must have just been beating it's self to death on the valve with it stuck.. Heads are at the machine shop now getting a thorough rebuild.
  34. #102
    Jul 2020
    Spencer, MA
    Was the valve bent or just carbon build up? Look at your piston carefully for a mark. Roll the pushrod on a flat surface to see if it's bent. The valve spring could have coil bind if not the right ones for the cam lift. Look at the others at full valve lift when you turn the engine over by hand. I don't know how adept you are at engine building so just ignore me if you know all this stuff. The rollers on the end of the rockers should be centered on the valve stem at half lift. If not you get too much side pressure on the valves. Longer or shorter pushrods would be needed to correct accordingly. You tube has a bunch of videos on the subject. Wish you the best.
  35. #103
    Sep 2022
    Huntington, IN
    It gets worse... I pulled the lifters and found "crud" in the grooves, then looking at the block with a flashlight, I can see a bunch of rusty crud in the oil passages.. Looks like someone didn't clean the block good enough after bore and hone or not at all. So the block is heading to the machine shop to join the heads. Also looks like some of the valves kissed the piston so that'll get addressed as well. Complete rebuild. Hopefully we can use the crank, rods, pistons, cam & lifters. Just disassemble, clean and reassemble with proper clearances this time. Then a good engine dyno session to dyno tune it.
  36. #104
    Ugh. This is another of those situations where we need a button that says “I’ve been there, it really sucks, I’m sorry to hear it but it’ll be much better after you fix it”
  37. Likes Just 1 More, FF33rod liked this post
  38. #105
    Jun 2018
    Yup, totally sucks. My 347 lasted a couple of hours before a crack in #1 turned it into a steam engine and another rebuild.
  39. Likes Just 1 More liked this post
  40. #106
    Senior Member Ltfracing's Avatar
    Aug 2022
    Are you going to sell the jegs wheels and tires ,thank you
  41. #107
    Jul 2020
    Spencer, MA
    That's a tough one. At least you'll know it's right
  42. #108
    Sep 2022
    Huntington, IN
    Yeah, It wasn't money I expected to spend but now i'll know. I'm in the process of finding a transmission shop that will go through the 700R4 since I don't trust anything about this now.
  43. #109
    Sep 2022
    Huntington, IN
    Yes, When I'm done with them as rollers
  44. #110
    Jul 2020
    Spencer, MA
    I used to rebuild those when I was working. Did more transverse ones than anything else though.
  45. #111
    Sep 2022
    Huntington, IN
    So pretty i'm never taking the plastic off.. lol
    big thanks to Kim & Matt Gossett @ mcbparts.com for helping me get these from Schott Wheels. It'll probably be another year before they get on the car but so happy to have them.
  46. #112
    Jun 2020
    SoDak
    Love the Bonneville style wheels, I have similar one on my 33 except gray, not black.
    Jim
  47. Likes Just 1 More liked this post
  48. #113
    Sep 2022
    Huntington, IN
    I've been taking a break from the '33 but it was time to get back on it. Pulled the rear end, cleaned it real good, pulled the axles and replaced the seals. Wire brushed the calipers and painted them. Hopefully get it back in tomorrow with the new Ridetech lower arms and BMR uppers. Added a Moser cover just because. Has 3:73 gears
  49. Likes Mastertech5 liked this post
  50. #114
    Sep 2022
    Huntington, IN
    Got it back in... the Ridetech uppers and BMR swivel bushings and Ridetech lowers with double R joints, Waiting on the new drilled/slotted rotors then I can put the wheels and tires back on it.
    20230611_183127 by F G, on Flickr
    20230611_183028 by F G, on Flickr
    20230611_182957 by F G, on Flickr
  51. Likes RoadRacer liked this post
  52. #115
    Looking at this closely, did you manage to offset the spacers front/rear of the LCA to make it more parallel to the car? That's what I did using Levy's LCA..
  53. #116
    Sep 2022
    Huntington, IN
    Mine are dead center, no offset. It looked pretty good but now i'll have to go look at it again and see if i'm missing something. Those inner nuts are actually spacers. I drilled the threads out and used them because they were the perfect width.
  54. #117
    Cool, if you're ever interested in what Gordon Levy suggests (and makes sense to me), you can see how the offset spacers work in the first photo here:
    https://thefactoryfiveforum.com/show...l=1#post478520
  55. #118
    Sep 2022
    Huntington, IN
    Pads and rotors arrived today so I buttoned up the rear, all that's left is the bleeding. And of course I just had to see how the new rims looked on there.
    20230615_181325 by F G, on Flickr
    20230615_181304 by F G, on Flickr
    20230615_181347 by F G, on Flickr
    20230615_191516 by F G, on Flickr
    20230615_191523 by F G, on Flickr
    20230615_191538 by F G, on Flickr
  56. Likes RoadRacer, Ltfracing liked this post
  57. #119
    Jul 2020
    Spencer, MA
    Nice wheels! The two most personal things in a build are #1-wheels, #2-paint. There are 1000s of wheel designs but paint is various shades of spectrum colors.
  58. Likes Just 1 More liked this post
  59. #120
    Jun 2020
    SoDak
    And I'll add, that some wheels that look good with some colors just don't look right with other colors. It can be maddening when you get to the point of wheels & colors. That was the hardest part of my build was figuring out what color to go with. Then on my 55 F100 Build I'm wrapping up now, I knew the color I wanted but finding the right wheels to go with it was the biggest struggle. Ugh
    Jim
  60. Likes Mastertech5 liked this post
