Thanks Thanks:  3
Thread: First Oil Change. Conventional or Synthetic?
    Title says it all.
    thanks
    Bill
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    My engine builder said to always run conventional 10w30 or 10w40. Told me to stay away from synthetic oils in these pushrod engines. I have been using Lucas HotRod 10w40.
    https://www.amazon.com/dp/B01MCWTN71...roduct_details
    Build #9818 completed 04/2021 - Dart SBF 427, PF4 EFI, TKO600 Build thread: https://thefactoryfiveforum.com/show...utton-head-mod
    Build review video:https://www.youtube.com/watch?v=k6IAbo2sFt4&t=1111s My finished car: https://thefactoryfiveforum.com/atta...7&d=1638415131
  3. Thanks 2FAST4U thanked for this post
    Dinosaur oil until at least 500 miles but really, for no more miles than you’ll put on there is no reason to ever go synthetic unless you’re going to track the car and need the additional heat tolerance.
  5. Thanks 2FAST4U thanked for this post
    Likes Fman liked this post
  6. #4
    Dublin, OH
    remember the zinc (ZDDP) if flat tappet.
  7. Thanks brewha thanked for this post
  8. #5
    Grand Rapids, MI
    When my 427 Windsor was built the builder recommended Mobil 1 10-30 past the normal break in. Did the same after the rebuilds, I'm hard on equipment and broke it a few times. Always seemed to work for me.
    Jim
    2016 Mk4 Challenge Car, IRS, 3.31 Torsen, RDI Aluminum 427w, AFR 225s, Vic Jr. ProSystems 780 HP, TKO-600 w/Liberty mods. Forward cage. Levy 6/4 piston Wilwoods. Not completed yet, will be a streetable track car.
    2004 Superformance MkIII #1855, 2007 Superformance MkIII #2584 purchased in 2012 both sold.
