Thanks Thanks:  4
Likes Likes:  41
Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: Chassis number 1340
    Jun 2020
    SoDak
    On Gen2 with full fenders/running boards you need to use the bottom holes.
    Jim
  2. Thanks Ltfracing thanked for this post
    Likes Ltfracing liked this post
  3. #42
    Jul 2020
    Spencer, MA
    Lower holes for full fenders and trucks. Upper holes for no fenders or bike fenders. NOTE: If you go with the lower holes there is no going back as you need to cut the top of the rearmost lower control arm mounting bracket to have enough clearance for the steering rack. It's in the build manual. It's a personal choice though if your not using full fenders. More rear tire clearance, although adjustable with the coil overs, and more road to frame, or exhaust, clearance. I chose the lower holes, potholes and speed bumps, to save the cats which are round and hang some what low.
  4. Thanks Ltfracing thanked for this post
  5. #43
    Senior Member Ltfracing's Avatar
    Aug 2022
    Moving steering shaft over to the right 3 inches to straighten funky angles out and moving brake pedal over to where clutch pedal would be
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  6. #44
    Aug 2022
  7. Likes Just 1 More liked this post
  8. #45
    Sep 2022
    Huntington, IN
    Looks like you had a busy weekend
  9. Likes Ltfracing liked this post
  10. #46
    Aug 2022
    Got my block hugger headers in
  11. Likes RoadRacer, Mastertech5 liked this post
  12. #47
    Aug 2022
  13. Likes TxMike64, Mastertech5 liked this post
  14. #48
    Aug 2022
  15. Likes TxMike64 liked this post
  16. #49
    Wisconsin
    Hi LTF, Re: Mounting bolts for Shocks at Front End................
    It's best to have the NUT nearest the radiator not the bolt head. When it comes time to change things, you don't want to have to move the radiator to get the bolts out.
    Once you put the Fan Shroud and fan in place it gets pretty crowded around those fasteners.
    (I learned this from experience!)
    Best wishes,
    Tom
  17. Likes FF33rod, JimLev liked this post
  18. #50
    Aug 2022
    From building race cars my whole life all bolts go front to back ,it’s a hard habit to break,if nut falls off bolt will not come out with car moving forward
  19. Thanks Tom Veale thanked for this post
  20. #51
    Jul 2020
    Spencer, MA
    When did you get the grill? Looks good!
  21. Likes Ltfracing liked this post
  22. #52
    Aug 2022
    Just got it the other day,thank you sir
