TKO/TKX vs AOD transmission question
Note that I already have this question into FFR Tech Support but I thought I would also ask the collective brain trust here:
I just received the final invoice for my order and noticed that it lists the kit as coming with the TKO/TKX transmission option as opposed to the AOD option that I had originally asked for.
Does this make any difference? Do I need to get the invoice fixed?
Note that I'm in Canada so I'm already getting my driveshaft separately in the correct length for the AOD, assuming that's the only impact on what parts are needed/supplied...
Earl
1st Speedstar in Canada 31 March 2023.
Built by me 302 engine, AOD trans, 3.55 IRS.
If anybody cares note that as per FFR it doesn't make any difference in my case....as I have the AOD correct length driveshaft already coming.
Earl
Post Thanks / Like - 0 Thanks, 3 Likes
The only difference I can possibly see would be the trans mount itself and the length of the spacers. Probably the same as the AOD because you are installing a Ford engine, as the TKX is made to fit each manufacturers configuration. I think you are good!
