Thanks Thanks:  2
Results 1 to 3 of 3
Thread: bpe 306
    Jan 2018
    bpe 306
    i have BPE 306 with holly sniper. approximately what should the manifold air pressure be at idle?
    mburger's Avatar
    Punta Gorda FL
    Hey padre. A quick call to BPE should get you the info. Very short wait times usually.
    Mark
  3. Thanks padre thanked for this post
    bobl's Avatar
    Spicewood, Texas
    Quote Originally Posted by padre View Post
    There are so many variables there is not really a good answer. Altitude, cam profile, idle speed, timing, engine health, and so on will affect it significantly. With that said, I've tuned a couple of mild 302s w/sniper and the idle map reading is generally between 40 and 50 kpa at 1000' elevation. I believe a stock 302 pulls 18-20" of vacuum, which is around 40 kpa.
  5. Thanks padre thanked for this post
