Thanks Thanks:  8
Likes Likes:  43
Page 2 of 2 FirstFirst 12
Results 41 to 75 of 75
Thread: My New Project
    Senior Member MPTech's Avatar
    St. Louis, MO
    This is going to be a very cool Truck Project! Keep sharing pics.
  2. Thanks 2FAST4U thanked for this post
  3. #42
    wallace18's Avatar
    Trenton, Florida
    Very nice work!
    16+ FFR kits and counting!
  4. Thanks 2FAST4U thanked for this post
  5. #43
    Sway bar installed
  6. Likes JimLev liked this post
  7. #44
    Spent 4-1/2 hours today installing:
    The rear end
    The 4-link suspension
    The pan hard bar
    Rear sway bar
    Rear coilovers
    Rear brake calipers
    Rear flex brake lines
  8. Likes Geoff H liked this post
  9. #45
    Received my 19 gl fuel tank and set about modifying it to fit the TCI chassis (it’s designed to fit an original chassis). I had to cut down the side mounting flanges, fabricated two side mounts and a rear mount. The side mounts are attached to the frame with 3/8” hex bolts. The rear mount is attached to the frame with 1/4-20 bolts. I welded the nuts to the three brackets so it will be easy to remove and install the tank. After making sure everything fit, I removed it all and painted it with gloss black POR-15.
  10. #46
    May 2021
    Fort Worth, Texas
    Nicely done!
  11. #47
    Been slowly filling the holes in the firewall. Very slow process. About half done
    Started by welding a backing plate over the holes from inside the cab. Then filling the hole with JB Weld epoxy. Sand and fill with body filler. Sand and fill again. Sand and primer
  12. #48
    New glass installed
  13. #49
    Started installing sound insulation
  14. #50
    Fabricated a behind-the-seat panel from 0.048 mild steel. Still need to do the corners but they’re a bit tricky because of their curved shape
  15. #51
    Fabricated a patch panel and modified a hump back transmitting hole cover from Summit Racing to fit the gaping hole cut in the floor bynthe previous owner
  16. #52
    Painted the inside of the cab with POR-15
  17. #53
    May 2021
    Fort Worth, Texas
    Looking good!
  18. #54
    Finished filling in the holes in the firewall. All done and painted satin black
    Bill
  19. #55
  20. Likes JimLev liked this post
  21. #56
    May 2021
    Fort Worth, Texas
    Beautiful work.
  22. #57
    Spent the break in storms (they return tomorrow) to work on the ‘54. Removed the rear fenders that were literally welded from decades of rust. Lots of PB Blaster, heat from a propane torch, and lots of muscle and they relinquished their hold. I cleaned everything up with a power washer, then applied a coat of POR-15 to the inside of the fenders and the area on the bed where the fenders attach. Tonight I applied Herculiner bedliner to the fenders and the area where the fenders attach to the bed. I also ordered new hardware and fender-to-bed seals.
    Bill
    Progress baby!
  23. #58
    May 2021
    Fort Worth, Texas
    Looking good!
  24. Likes 2FAST4U liked this post
  25. #59
    May 2021
    Fort Worth, Texas
    Made the mistake of showing this to my better half. She has been wanting an old truck for a long time. Now,...I created a monster. She is on me to finish my car and get her project truck going.
  26. #60
    It was a great day with the ‘54. I assembled a crew of 4 people (me and 3 neighbors) to tackle the task of taking the bed off the old frame and placing it on the new frame. I made a dolly on which we lifted the bed off the old frame, moved it into the garage, used my overhead hoist to lift the bed, move the new frame under the bed, and then gently lower the bedmin place. Took a whole 36 minutes. Afterwards, I treated “The Crew” to lunch for a local BBQ place.
    Bill D
  27. #61
    Bill D
  28. #62
    May 2021
    Fort Worth, Texas
    Nicely done! I love my overhead hoist. It straddles my lift, which makes short work of heavy lifting and placement. My hoist is also on wheels.
  29. Likes 2FAST4U liked this post
  30. #63
    Fabricated a rod style seat adjustment system. The ‘54s used a complex cable system that no one makes reproductions for. So I had to design my own using ‘55 seat adjusters, welded two rods together, cut the welded rod to length, then welded the rod to metal flats that are attached with screws and locknuts to the seat adjusters. Tested and works
  31. Likes Skuzzy liked this post
  32. #64
    Laid out the boards for the truck bed. Going to look great
  33. #65
    May 2021
    Fort Worth, Texas
    Is that kiln dried wood? If not you could be looking at loose knotholes in the near future.
  34. #66
    Kiln dried and stained. All pieces fitted today
  35. Likes Skuzzy liked this post
  36. #67
    May 2021
    Fort Worth, Texas
    Looking sharp.
  37. #68
    It’s been a most productive week depsite the inclement weather. It cleared today so moved the Challenger outside, move the new frame over, and installed the fenders, wired the taillights and license plate light, added a fuel fill hose, finished staining the bed wood and installed it, and finished it off with a flush mount fill cap
  38. #69
    May 2021
    Fort Worth, Texas
    Looking good! Nice choice on the wheels.
  39. Thanks 2FAST4U thanked for this post
  40. #70
    My kids bought me a 24” slip roller for my birthday. I proceeded to make the curved corners for the cab. Another task complete
  41. #71
    Today some friends helped me remove the cab from the old frame. Now I can prep the cab to take to the painter to refurbish the interior
  42. #72
    Now have all four tires and rims. Looks so cool
  43. Likes MPTech, Nigel Allen, Skuzzy liked this post
  44. #73
    May 2021
    Fort Worth, Texas
    Dang it! My better half saw me looking at this,...She goes,..."I WANT ONE!".
  45. Likes 2FAST4U liked this post
  46. #74
    I started some work inside the cab over the weekend. I decided to cover the dash holes used to mount the original rear view mirror. First, I attached a piece of 0.040 mild steel to the underside of the dash with some JB Weld. I let it cure for 24 hours. Then I sanded the top side and filled the holes with body filler. Today I sanded the area with 220 grit sandpaper until smooth. Finally, I sprayed the area with automotive primer. Tomorrow I’ll sand the area first with 320 grit sandpaper, add more primer, and finish with 400 grit. It will eventually get finished by my painter
  47. #75
    May 2021
    Fort Worth, Texas
    Nice.
