Thread: MK4 USRRC/FIA Radiator Angle
    Jan 2022
    Seattle, WA
    In researching radiator angle so I can get the lower radiator hose length in the ballpark, I’ve seen 51 degrees listed as what the typical MK4 needs. Wondering if someone can confirm if that is the same on the USRRC 289 body.
    Lars
    Novice Build: 289 USRRC Complete Kit #10524, 3rd Gen Coyote, TKX, IRS, 17" Halibrands, Wilwood Brakes, Power Steering
    Sep 2015
    Beachside
    Hi Lars,
    The 289 radiator angle is much shallower, more like 40 degrees.
    FFR #8833 289 FIA 3-link
    Jan 2022
    Seattle, WA
    Quote Originally Posted by cnutting View Post
    Hi Lars,
    That's what I was worried about. Do you think 40 degrees close enough to cut the hoses and do the final adjustment after the body goes on?
    Lars
    Sep 2015
    Beachside
    Mine sits at 40. I ended up replumbing after I did the rough body fit and had all the mounting workeg out.
    Jan 2022
    Seattle, WA
    Thanks Chris. I think it's time to install the body to get this dialed in. I re-read your build thread and it gave me bunch of new insights that hadn't occurred to me from reading it before I began my build.
    Lars
  6. Likes cnutting liked this post
    Nov 2016
    "The i.e." SoCal
    Use the side pieces for the nose aluminum to set your radiator angle.
    Jan 2022
    Seattle, WA
    Thanks Frank. Can I do this without the body on? I was thinking I needed to have it in place to get the aluminum pieces into the correct position.
    BTW I really appreciate the information you provide on your YouTube channel.
    Lars
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by lasse2 View Post
    Don't know what you are using to hold the top of the rad in place. But you should be able to use the ziptie method in the manual to bring the bottom of the rad up until the side nose aluminum fits in nicely. Don't fasten the nose aluminum in, just use it as a template to get the angle. Then if you're using an adjustable lower mount you can get it installed while the zipties hold the bottom in postion. Wait until after the body goes on after paint to permanently mount the nose aluminum.
