http://www.factoryfive.com/whatsnew/.../ksupdate.html
Official KONI Shock Recall Notice I wanted to take a moment to let you guys know about a potentially serious matter that requires your immediate attention.
Recently we received a report from a customer regarding a KONI shock absorber that had failed. This is the only incident of a broken KONI shock that we have received. We immediately obtained the part from the customer and forwarded it to the guys at KONI. It was quickly determined by the technical guys at KONI that the root cause of the failure was due to a cold weld. KONI and Factory Five Racing, Inc. are taking immediate action to replace any affected parts in the field.
The potentially affected shocks are in a small range of about 125 customers and were delivered in FFR kits and parts sales AFTER February 2010. We have identified the potentially affected lot numbers and are asking you to check your shocks for the following batch numbers:
Part Number: 30-1720, Date Code: 07-2010
Part Number: 30-1721, Date Code: 07-2010
Part Number: 30-1721, Date Code: 13-2010
