G’day all,
Just wondering if there is anyone on the forum with CANbus / Arduino experience? I have a project for my Roadster where I would like to build a ‘watchdog’ for my Gen1 Coyote. Basically I would like to build an Arduino based device with a CANbus shield to interface to the Coyote CAN.
The ultimate plan is to be able to monitor oil pressure, coolant temp, battery volts to trigger a relay when thresholds are exceeded. This relay would bring up an indicator / alarm on the dash.
In addition, there is no output on the Gen1 ECM to trigger a MIL indicator. At the moment I plug in a handheld reader to check for MIL / faults. Some research shows that there is a bit that is toggled for the MIL. On my reader is has a MIL indication LED.
Although competent in electrical / electronic control systems, I am not knowledgeable in Arduino programming. I have a couple of friends who are, albeit not in interfacing to CANbus. I sourced an Arduino and CAN shield. We did some basic experimentation, but were unable to successfully read the stream of data from the ECM. It just seemed to be gibberish.
I would be truly grateful if anyone on the forum could help me at least to get an Arduino to successfully read the CAN or point me in a solid direction. Will send Aussie care package of quality beers (Not Fosters)
Many thanks,
Nige
