Thread: my mistakes = your benefit, fog/driving light buttons from billetautomotive buttons
    Folsom, CA
    I have two of these, both a little different - they're new but I've attached spade connectors and labels
    1st one 22mm,the hole that you cut out is 22mm, has "DRIVING LIGHTS" laser etched
    face/head size 25mm
    blue backlit
    5A: Nickel plated shell, LED back-lit etching. (only the etching on the center of the button is back-lit) 5 amp rated SPST switch
    $30 shipped
    2nd one is 19mm, the hole you cut out is 19mm, has "FOG LIGHTS" laser etched
    face/head size 22mm
    white backlit
    16A: Nickel plated shell, LED back-lit etching. (only the etching on the center of the button is back-lit) 16 amp rated SPST switch
    $25 shipped
    I changed my mind on my setup, so save about 20% on costs including shipping
    Todd
    Folsom, CA
    bump adjusted prices and showing amperage per switch as well
    Todd
    Folsom, CA
    bump for more views - anyone interested?
    Todd
    Folsom, CA
    bump
    Todd
    Folsom, CA
    bump - make an offer
    Todd
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    How do they operate? Push on/push off?
    Nov 2012
    Danbury Ct.
    PM sent
    Folsom, CA
    bump!
    Todd
