Thanks Thanks:  5
Likes Likes:  5
Results 1 to 11 of 11
Thread: Replacement shocks, Which ones?
    Sep 2022
    Huntington, IN
    Anyone know what the COMPRESSED / EXTENDED HEIGHT measurements are for the shocks?
    What spring weights?
    I'm looking at the QA1 or Viking double adjustable and need some measurements if anyone has that info.
    Thank you
    Jun 2020
    SoDak
    I don't know a lot about Viking shocks.
    I went with QA1
    * Front = QA1 DD403 Proma Star Double Adjustable coil over shocks with 9" long 300# springs
    * Rear = QA1 DS601 Proma Star single Adjustable coil over shocks with 12" long 300# springs
    For the front DD403 shocks you'll also need the following:
    https://www.summitracing.com/parts/qa1-9018-113
    https://www.summitracing.com/search/...yword=qa1-bc02 I used the shorter bump stop on the front.
    I really like the set up I have now with the QA1 shocks and the spring rates.
    Jim
  3. Thanks Just 1 More thanked for this post
    Likes Just 1 More liked this post
    Sep 2022
    Huntington, IN
    I went with QA1
    Jim
    Thank you very much for that info
  5. Likes JimLev liked this post
  6. #4
    Sep 2022
    Huntington, IN
    That second summit link isn't working for me. What is it supposed to be?
  7. #5
    Jun 2020
    SoDak
    Bump stop for the front shocks --> https://www.summitracing.com/parts/qa1-bc02
    Jim
  8. Thanks Just 1 More thanked for this post
  9. #6
    Jun 2020
    SoDak
    QAI shocks unlike Koni can be inverted so the adjustment knobs are in the engine compartment verses having to crawl under the car always. Much nicer. The links I sent are needed to invert the QA1 in the front, sorry I didn't note that sooner.
    Jim
  10. Thanks Just 1 More thanked for this post
  11. #7
    Sep 2022
    Huntington, IN
    Jim
    Curious why you went single adjustable in the rear instead of double?
  12. #8
    Jun 2020
    SoDak
    With these cars being so light in the rear and with me going with a little stiffer spring (300# vs. 250# from FFR) there was little advantage to having the rebound adjustment in the rear so that is why I only went with single adjustable (compression only). Just personal preference.
    Jim
  13. Thanks Just 1 More thanked for this post
    Likes Just 1 More, JimLev liked this post
  14. #9
    Placitas, NM
    Jim, I sent you a PM about your rear 250 lb springs.
    I checked mine they are 300 lb.
  15. #10
    Oct 2022
    FWIW, my 33 delivered Aug 22 came with 250 lb springs in the rear and 400 lb springs in the front.
  16. Thanks JimLev thanked for this post
  17. #11
    Thank you
    I'm still running the original non-adjustable shocks, albeit with stiffer springs (now up to 800/450) - but I hear a lot from folks saying the adjustable ones will be "so much nicer". I know almost nothing about shocks, so curious what everyone's experience is?
    In what way are better shocks better, and would they still be better with my stiffer springs? Are they better on road or track or both? I'm sure there is more control, and obviously adjustability, but I'm not sure what the end result of that actually is?
