Thanks Thanks:  5
Likes Likes:  46
Page 3 of 3 FirstFirst 123
Results 81 to 89 of 89
Thread: Bill Elliott's "Living the Dream" build thread.
    Jan 2023
    Woodway, TX
    Finished wiring for the cup holders and usb charger.
    Also picked up my new Cobra transport . 8.5 x 20 Continental cargo.
    Delivery Date 6-24-23 Build thread Living the Dream
    SBF 427 564hp/576tq Holley Sniper with Hyperspark by Smeding Performance. Tremec TKX .68 OD. IRS . Wilwood 12.88 brakes. Wilwood EPB. First start 11-17-23. First go cart 11-20-23.
  2. Likes Mike.Bray liked this post
  3. #82
    Jan 2023
    Woodway, TX
  4. #83
    Jan 2023
    Woodway, TX
    I ordered the larger sleeves for the front quick jacks to be mounted with the large grommets. Makes a much nicer mounting fit and look. I was really nervous about cutting into the body for the grommets (there's only so much a body man can fix, unless your Jeff of course .) . I still have to get some acorn nuts or something to give it a better appearance. I also need some rubber washers for the rear quick jacks where the washer goes against the body.
  5. #84
    Jan 2023
    Woodway, TX
    Did some floor work for the trailer. Something hauling the Cobra needs to be appropriately treated. This is the Rustoleum epoxy 2.5car kit.
  6. #85
    Jan 2023
    Woodway, TX
    Things are progressing fairly well. Still have to get the body sitting just right. Finished most of the interior yesterday. Next will be the side louvers and undercoating of the body.
  7. #86
    Jan 2023
    Woodway, TX
    Getting closer to almost finished, as finished is probably never said. Worked on getting doors and trunk installed still have to do trunk latch and license plate mount. The doors are a true test of patience. Luckily I only have to get them to function, the final adjustments will be finished by a pro ! I also got the headlights installed and am using the daytime running light with them. It can be set to amber or white, for now I like the white.
    daytime running lights.jpg headlights installed 1.jpg headlights installed 2.jpg doors installed.jpg trunk installed.jpg
  8. #87
    Dec 2021
    Flower Mound TX
    I have headlights with amber and white halos, I'm using one color for daytime running lights and the other color for my turn signals.
  9. Thanks Bill Elliott thanked for this post
  10. #88
    Jan 2023
    Woodway, TX
    I thought about that , these can be white or amber . I didn't think they would show up very well as a turn signal with the headlights on.
  11. #89
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Bill Elliott View Post
    They're pretty bright.
    I used these lights. https://www.carid.com/1965-ford-gt-h...parentsubmodel[]=SUBMODEL|With+Factory+2-Headlight+System
