Likes Likes:  9
Results 1 to 23 of 23
Thread: QA1 DD403 FRONT Shocks, what springs?
    Sep 2022
    Huntington, IN
    For the guys that swapped to the QA1 DD403 front shocks, what springs did you go with?
    Jun 2020
    SoDak
    I'm running 300# 9" long springs in the front with my QA1 DD403 coil overs. Very comfortable ride.
    Jim
  3. Likes Just 1 More liked this post
    Placitas, NM
    I did pretty much the same as Jim, QA1’s
    Front - 9” 300 lbs
    Rear - 12” 275 lbs
    I did get some 8” 250 lbs springs from Jim that I decided not to use.
    I’ll be giving them away and then selling the Koni coilovers that came with my hotrod.
    (The Koni’s were sold)
    Jun 2018
    North Vancouver, BC, Canada
    I went down to 220 on the fronts. A lot nicer than the original... I left the IRS springs as is.
    All I do is cruising. If you want to AutoX, you actually need to go the other way!
    Gen 1 '33 Hot Rod #1104
  6. Likes Just 1 More liked this post
  7. #5
    Sep 2022
    Huntington, IN
    So what's the deal going with shorter springs? Aren't these supposed to be 10" springs?
  8. #6
    The springs touch if you lower the car on the longer springs. I’m running 800/450 springs now and all 7”
  9. #7
    Placitas, NM
    Springs all depend on the weight of the car. The back won’t change much but the front can depending on the size of the engine and if it cast iron or aluminum.
  10. #8
    Jun 2020
    SoDak
    Quote Originally Posted by Just 1 More View Post
    The springs that come with the FFR kit are 8" long, I went up to 9" in the front and 12" in the rear.
    Jim
  11. Likes Just 1 More liked this post
  12. #9
    Sep 2022
    Huntington, IN
    800/450??? Dang, I would think that thing rides like a brick
  13. Likes JimLev, RoadRacer liked this post
  14. #10
    Sep 2022
    Huntington, IN
    Jim
    Thanks, For whatever reason, I thought they were 10"
  15. #11
    Jun 2020
    SoDak
    No problem, for some reason FFR's spring were short little things (8"), that's why in the rear most builders have their Koni's adjust almost to the top of the threads to get the right ride height. Even in the front the 8" seems too short which is why I switched to the 9".
    Jim
  16. Likes Just 1 More liked this post
  17. #12
    Jul 2020
    Spencer, MA
    They sent me 9" fronts and 10" rears. I had to wait a couple of months for the front springs to show up.
  18. #13
    Jun 2020
    SoDak
    Quote Originally Posted by Mastertech5 View Post
    Sounds like they started to listen to a bunch of the folks saying 8" were not long enough. That's great.
    Jim
  19. #14
    You’re not wrong.. but after 2.5 years of tweaking I finally have a car that plants the outside tire correctly.. which equals speed! First in class last week
  20. Thanks Just 1 More thanked for this post
  21. #15
    Oct 2022
    Jim
    What is the advantage of longer springs assuming the same spring rate?
    I got daring yesterday and took my Speedstar for a drive out of the neighborhood. It gave me a chance to get up to about 50 mph and go through the gears. One thing I noticed was the back end was pretty jarring, the front didn't seem bad.
    Since the spring is way up the body of the shock there is plenty of room for a longer spring. Maybe a progressive wound spring or dual rate springs.
    Also, what are folks running for air pressure on the hot rod. Saw a post where the recommended air pressure for the roadster is 22-23 psi. Don't know how much heavier the the hot rod is but based on this I should have a lot less than the 35 psi currently in the tires.
  22. #16
    Jun 2018
    Quote Originally Posted by Dgc333 View Post
    Roughly 1 psi per 100 lbs - so 24ish is the right range. This changes the ride significantly.
    As for springs in the rear, what rear are you running? the IRS is quite different from the straight axles....
  23. Likes RoadRacer liked this post
  24. #17
    Oct 2022
    I have the three link and the kit came with 250 lb/in springs for the rear and 400 for the front.
  25. #18
    Sep 2022
    Huntington, IN
    Aren't the Koni springs a 2.5" spring? Same as the QA1? If that's the case, Can't I use the Koni 400# on the QA1 as starting point?
  26. #19
    Yes, same diameter 2.5". springs are interchangeable.. and let me know if you need different springs, I have a box full
  27. #20
    Sep 2022
    Huntington, IN
    Thanks James, I'll start with the 400's and if I ever get this thing on the road, i'll adjust from there.
  28. Likes RoadRacer liked this post
  29. #21
    Placitas, NM
    400 in the front are pretty stiff.
    I changed my front and rear springs, see post #3.
    I still have 8” 250 lb springs for free if you or anyone else wants them.
  30. #22
    Sep 2022
    Huntington, IN
    QA1 recommends a 10" for the DS403 shocks. The ones I have from FFR are 8" .. should I go with 9" or 10"? Keep in mind, i'm installing these inverted with the more cone shaped QA1 top retainers 9018-113
  31. #23
    Sep 2022
    Huntington, IN
    A little more measuring, I can see with the std shock top retainer that a 10" would be correct, with the more tapered top retainer the 9" should be the ticket.
