Likes Likes:  2
Results 1 to 14 of 14
Thread: Explain it to me - top or bottom hole upper shock mounts
    Sep 2022
    Huntington, IN
    The manual says not to mix holes, all upper or all lower. I don't see how using either the upper or lower hole in the top shock mount will do anything to the function or geometry of the suspension other than length of shock which you're changing anyway by adjusting the spring collars, NO?
    Technically, I think you're correct. But that setup (I have the same in my truck build) doesn't have a lot of shock travel to adjust. Depending on your planned ride height, you could run out of adjustment one way or other other. IMO, not quite as simple as use either hole and make up whatever difference is required by adjusting the spring collars. Use the hole that gives you the most adjustment. In my experience, a street machine with "normal" ride height is going to need the lower hole.
  3. Likes Just 1 More, Mastertech5 liked this post
    Sep 2022
    Huntington, IN
    I'm going to use the QA1 shocks mounted inverted to be able to access the adjustments. I just can't figure what difference it would make to use the upper vs lower holes in the upper control arm.
    Quote Originally Posted by Just 1 More View Post
    The brand shocks and where you place the adjuster really doesn't matter for your question. I don't know how to explain any differently. I did look back at your picture though and see you have the entire suspension in the upper holes. In that case, following the Factory Five instructions, the shocks should also be in the upper holes. I would only caution you that the entire setup needs to be taken into account, e.g. your desired ride height and the tires/wheels you're using. The hot rod (and truck) has the grille quite low in the front. My truck build (same front suspension as the hot rod) has front ride height at 5-1/2 inches, rear at 6 inches, 18 x 8 wheels and 245/45ZR18 tires all around. I used the lower suspension holes and my grille is no more than 3 inches off the ground.
    Sep 2022
    Huntington, IN
    Ride height is definitely a concern with the low nose on these things. That'll be a game time decision once the wheels and tires and body all go on together to see where she sits. If it's too low, i'll swap everything to the lower holes.
    Jul 2020
    Spencer, MA
    I put mine on all the lower holes for a higher ride height. My Cat/converters hang down further than the rest of the exhaust because of their diameter. Speed bumps and pot holes were also a consideration. I also chose 40 series tires on 18x10s rear and 17x8.5 in front. I have seen too many cracked or bent wheels that had lower profile tires on them. The fronts are at the max FFR suggests, the rears are 3 tenths over. I believe 26.5 " is the suggested max tire diameter. The manual says to place the grill height at level or slightly lower for the hood rounded bottom compared to the rounded "molding" on the body.
    Sep 2022
    Huntington, IN
    I found out yesterday that if you're doing the inverted QA1's you must use the lower shock mount hole, the shock hits and will not allow you to use the upper hole.
  9. #8
    Placitas, NM
    So with the Koni’s is this still a problem?
    What if you flip the QA1’s over?
  10. #9
    Are you saying it hits at full droop, when the car is airborne?
  11. #10
    Jul 2020
    Spencer, MA
    I believe there are extensions for that so the shocks won't hit.
  12. #11
    Sep 2022
    Huntington, IN
    The body/base of the shock will not allow the mounting hole to reach the top control arm hole, no matter what ride position. I honestly don't see an issue with this as the only thing this would effect is ride height which is adjusted by the coil over anyway.
  13. #12
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Mastertech5 View Post
    They only hit if you try to use the upper holes. They do not touch if you use the lower holes
  14. #13
    Jul 2020
    Spencer, MA
    I believe JimLev did the same and I think he used the lower holes because he has full fenders.You unscrew the rod end from the shock rod and install a longer one. Mark Reynolds at Breeze Automotive has some and can advise you. Give him a call. He's great.
  15. #14
    Sep 2022
    Huntington, IN
    Also, You can't change the mount end on the bottom of the shock, only the top of the shock, So any extension would be useless in this case..
