Ac question/issue - any help is greatly appriciated!!!
I'm pretty confident that I have all my wiring correct for the Factory Five supplied ac unit but here's my issue. My radiator fan comes on about 15 seconds after I turn the ac on but then shuts off. It keeps cycling on and off. On for 10 seconds, off for 15 seconds. its about 75 degrees here and I have a gauge reading of 45 on the low side and 175 on the high side. My first thought is that I don't have enough pressure in the system but both high and low are in spec. I don't want to just add more refrigerant without seeking some advice.
FYI the sight glass on the dryer is clear, no bubbles or foam.
Running a coyote and using the engine controlled fan. All of the tests that I've ran, the motor has been cold. Fan works as it should when the engine gets to operating temperature.
