Likes Likes:  4
Results 1 to 7 of 7
Thread: SpeedStar hood side panels
    Oct 2021
    The side panels fit GREAT!
    Almost zero trimming, goes in and out around the suspension easily.
    Fastens to the grill easily
    Fastens to the cowl easily (3 bonded bolts on each side)
    But how does it fasten in the middle?
    Just supports itself?
    There are no SpeedStar specific instructions that I have found.
    Anyone put one together yet?
    Thanks!
    Oct 2022
    I am just about ready to start fitting the side panels on my Speedstar, glad to hear they do not require a lot of trimming.
    As far as I know there is no connection in the middle.
  3. Likes theidlemind liked this post
    Kingsland, TX
    So is the chin piece specific to the Speedstar or is it the same as the regular '33? While I've read about the regular side panels being long and needing to be trimmed, I think most of the consternation n the front end is related to the chin piece. This goes under the radiator and ties the lower body pieces together.
    Oct 2019
    Erin, Ontario CANADA
    In my Speedstar kit the chin piece is "split" along the vehicle centerline with the two halves being part of the two hood side covers. If you were to join the two sides together you wouldn't be able to get the whole thing off.
    Earl
    1st Speedstar in Canada 31 March 2023.
    Built by me 302 engine, AOD trans, 3.55 IRS.
    Oct 2022
    I plan to make a strap that ties the two sides together for added support. I am going to go ahead and fit the side panels but I like the look with out them and may not put them on after paint. I have been putting miles on the car without them.
  7. Likes narly1, theidlemind liked this post
  8. #6
    Oct 2019
    Quote Originally Posted by Dgc333 View Post
    I've been looking for a rubber "H" molding to fit in between the two chin edges. I was thinking I would use that along with something to hold the two against each other.
    When I get to that point LOL. Something like this:
    Earl
  9. Likes theidlemind liked this post
  10. #7
    Jun 2018
    North Vancouver, BC, Canada
    A lot better engine cooling with out the side covers (even if the side has small openings in it like the Buick ventiports in mine), that's for sure....
    Gen 1 '33 Hot Rod #1104
