Thanks Thanks:  3
Likes Likes:  5
Thread: Brake Fluid
    Kingsland, TX
    Brake Fluid
    What fluid are yall using? DOT 3 / DOT 4 conventional polyethylene-glycol or DOT 5 silicone based? I think I'll use DOT 5 because it's safer for paint and other finished, even if it might need to be flushed more often. It's not that humid here so I'm not too worried about moisture.
    Thoughts? Tips?
    It’s been a few years since I delivered this lecture so guess it’s time to do it again...trust me on this---DO NOT USE DOT5. In a nutshell it is a silicone fluid and retains millions of tiny air bubbles making it compressible meaning you will never get a firm pedal. Additionally it is non-hygroscopic (does not mix with water) so any moisture will stay separated and since H2O is heavier than the silicone it will settle in the low points; i.e. calipers. Get the brakes hot, the water boils and you have no brakes! Stick with glycol based DOT3, 4 or 5.1 fluid.
  3. Thanks TxMike64, KippRacing, Bob Cowan thanked for this post
    Jul 2020
    Spencer, MA
    I double down on what Jeff says! The rubber in your system may not be compatible either.
    Edmond, OK
    Unfortunate ... for me. Build School recommended DOT-5 and that's what I did.
    Nearly 21K miles on the car across 4 years of being on the road. I don't drive it really hard, so rarely aggressive on the brakes.
    Clutch dot 3, brake dot 4 here.
    (The clutch specifically says no dot 4)
    Quote Originally Posted by OSU Cowboy View Post
    You sure that they didn’t recommend DOT 5.1?
    Dublin, OH
    just curious, when is dot 5 supposed to be used? based on it's high temp profile, I'm guessing race cars and bikes, but would require frequent flushing to prevent water from fouling the system?
    Kingsland, TX
    I understand the disadvantages to DOT5. But It's hard to get past the fact that it won't eat my finishes! I'll probably go DOT3/4 just for availability.
  10. #9
    Dublin, OH
    just think of it this way...your daily driver and most cars use DOT 3/4 with no issues. Just make sure you don't have any leaks and you should be fine.
    I did have a leaky rear caliper but was able to quickly find the source as the brake fluid and eaten away the paint I had sprayed on the stock calipers.
