Thread: Differential mounting fasteners in Coupe 65 IRS
    Oct 2022
    For my project, I have received the IRS for my Coupe 65 from FFR.
    In the manual, it talks about the "smaller/Shorter bolts" and the larger/longer bolts", but what are these fasteners?
    I don't have any prepackaged nuts and bolts with my new differential from FFR.
    Are there part numbers? Description of the fasteners?
    Chris Nicholls
    Sales Order's 201690
    206599
    Oct 2022
    Also, while I am at it...
    Though I received a box of IRS fasteners, and as I am assembling the toe adjustment arms, I can't find either of these
    HHBOLT 0.6250 - 11 x 2.5 x 1.25 - N (2)
    B18.2.3.4M - Hex flange screws, M14 x 2.0 x 80 - 34N (2)
    FFR says they have now delivered everything. There are some similar bolts in there, but definitely not these.
    I do have a local bolt shop that seems to have everything. Is the above information enough for them?
    Are they graded bolts?
    See if information in this thread helps. Several Factory Five responses: https://thefactoryfiveforum.com/show...n-Coupe-65-IRS
    FYI, Factory Five doesn't actively monitor here in case that's what you're thinking.
    Chris,
    I found this as I prepare to swap my differential.
    Maybe this will help.
    http://www.factoryfive.com/wp-conten...s-packlist.pdf
    Gen III #17
    20,000+ miles
