Likes Likes:  2
Thread: FFR MKIV - Go Kart Stage - Modern Look
    Member ADI's Avatar
    Mar 2021
    It`s definitively a sad moment. Life did throw a curved ball on my plans and I have no time at all to finish my build. Instead of collecting dust in the garage, I decided to sell it. If you have the desire to jump into a modern looking FFR MK-IV sooner than later that`s your chance.
    Here is my build thread:
    Specs / parts that are part of the sale.
    FFR MK-IV kit:
    Powder coated chassis
    Coyote Mounts
    Stainless steel exhaust
    Independent suspension
    Coil over Koni shocks
    Cut-out fiberglass
    All other hardware
    • Coyote Gen 3 engine
    • 6 speed MT82 transmission
    • Mustang Cobra Torsen rear differential
    • Engine management - FuelTech FT550 + 2 Nano + Sparkpro - Dyno tested with 470HP @ the wheels
    • Ford performance 60lb/hr injectors
    • Several parts for tuning the Gen3
    • Power steering from KRC
    • Wilwood front brakes
    • Wilwood pedal
    • Rear brake manual valve
    • Electric E-brake
    • Optima (yellow) battery w/ Breeze battery support on engine bay
    • Hi amp alternator from Mechman
    • Formacar MT82 adapter for shifter
    • Tailored driveshaft
    • Konig Wheels (Matt black R18 10.5 rear, R18 9.5 front)Nitto NT-101 tires (275/35ZR18 front, 315/30ZR18 rear)
    • Carbon fiber dash with glove box
    • Full set of Speedhut gauges
    • Full set of billet aluminum buttons (including on the transmission tunnel cover) and warning lights
    • All electrical components in conduits and connected with waterproof Deutsch connectors
    • New gas tank
    • Breeze trunk extension
    • Breeze seat support
    • Breeze Radiator shroud
    • Breeze Trunk cubby
    • Breeze KoolMat kit (not yet installed)
    • Heated seats hardware
    • Carbon fiber Ford Mustang gear shifter
    • Ford performance racing steering wheel with quick connect
    • Kirko low back seats (+ the FFR ones)Black Alcantara (3 yrd) for seats and center console (still on the roll)
    And much more that I`m probably forgetting to list.
    The car is at the "Go Kart" stage, meaning it runs and performs as it is supposed to. Whoever picks it up will have to finish the interior (upholstery) and move on to the body prep (have not touched anything on the body yet.
    All parts (aside of the engine/transmission and differential) were purchased new and I have all the documentation for it.
    As you can see in the picture or the build thread, my idea was to create a more modern look (all black, no chrome) with a dark color (dark blue) body, but at this stage it is up for the new owner to decide.
    Quick math showed me that I spend (hopefully my wife does not see this) more than $58K on parts alone, including the kit.
    Asking $50K.
    I`m in North Carolina in Chapel Hill. (2 hrs from Charlotte or 30 min from Raleigh)
    Please email / text for any inquires and hi def pics
    (919)-525 4826 - [email protected]
    Mk4 IRS Coyote Gen3 6 speed, FuelTech control,
    Build progress:https://thefactoryfiveforum.com/show...s-Build-Thread
  2. Likes CaptB, damiengerrior liked this post
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    That is a deal! Good luck.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  4. Thanks ADI thanked for this post
  5. #3
    Feb 2024
    Is the car still for sale? You can text me at 916-716-8376. Thanks. You have all the body parts I assume.
  6. #4
    Member ADI's Avatar
    Mar 2021
    Quote Originally Posted by 1969Camaro View Post
    text sent
