Thanks Thanks:  4
Results 1 to 12 of 12
Thread: Need Manual Steering rack bellows for Gen 1 33 Hot Rod
    Feb 2014
    Does anyone know where I could get new manual power steering rack bellows for my 33 Hot Rod. It was build in about 2014.
    I wonder who manufactured the rack.
    I checked the factory five website and didn't see any in the parts department.
    Stacked33
    Sep 2022
    Huntington, IN
    I don't know if 1st and 2nd gen are the same but I just replaced the ones on my 2nd Gen and this is the kit I got from Summit. https://www.summitracing.com/parts/FLA-FR1501B
  3. Thanks RoadRacer thanked for this post
    I don't believe they changed racks Gen1->Gen2. I got a replacement rack fairly recently from FFR, the same one I got in 2017 (Gen1).
    I hear the rack was custom - people are only ever buying them from FFR.
    Feb 2014
    OK, I will check out the ones from Summit. I know the one side is a smaller diameter than the other.
    Good to know they probably didn't change the rack between generations.
    Thanks for the reply's.
    Kingsland, TX
    I believe it's a Dodge Omni manual rack.
    Placitas, NM
    It does look like it was from a Dodge Omni.
    https://www.oreillyauto.com/detail/c...dge-omni?pos=1
  8. Thanks RoadRacer thanked for this post
  9. #7
    Sep 2022
    Huntington, IN
    Sep 2022
    Huntington, IN
  11. Thanks RoadRacer thanked for this post
  12. #9
    Love all this research! Narrowing this down to a particular one will solve a long-time mystery..
  13. #10
    Sep 2022
    Huntington, IN
    Feb 2014
    Update:
    I bought from Summit the Flaming River kit (FLA-FR1501B) suggested in post 2. I installed it yesterday and it worked great.
    Reminder, Gen 1, 33 Hot Rod, circa 2014
    Thanks for the input, stacked33
  15. Thanks RoadRacer thanked for this post
  16. #12
    I wonder if the manual rack boots for the MK-4 & Type-65 are the same inner and outer diameters are the 33 Hot Rod Rack?
    When I had the same issue with my MK-4 Roadster, I found that MOOG #K150289 worked very well.
    I know that the 33 rack is much much shorter but are the inner and outer diameters the same?
    Anyway, these bellows have a nice taper and a few more flexibility pleats.
    https://www.moog-suspension-parts.com/moog-k150289
