Results 1 to 2 of 2
Thread: Lower control arm boot
    Nov 2023
    Question Lower control arm boot
    On this assembly video ( https://youtu.be/oBJ5dKLrhoU?si=9f8ysPiLUlMA63Jb ), we see the person putting a rubber boot on the lower control arm. In our case, it came already with a rubber boot installed which is different from the one in the manual. In the box, it came two blue rubber boots. We don’t know if those are to be used on the upper arm and the lower arm came with them mounted or if it is missing two rubber boots to put on the lower arm.
    Would appreciate if anyone can help clarify this either through here or via email ( [email protected])
    May 2023
    Salisbury, NC
    Blue are for the top. Bottoms already have them installed. Many will suggest replacing the blue ones now while it’s easy to do with higher quality units such as Energy Suspension 5.13102G Ball Joint Dust Boot.
    MkIV Complete - Dart 427/TKX/Sniper II/IRS from Forte
