0
0
Mk4 clutch pedal stop
Any suggestions for a clutch pedal stop on a Mk4 with hydraulic clutch? I’ve seen an elevator bolt with a rivnut/nutsert in a frame tube, but that was an older model and the Mk4 doesn’t have the same tube. I over extended the throw out and caused a leak. Any suggestions are appreciated.
-John
John D. - Minneapolis 'Burbs
There have been plenty of creative solutions to clutch pedal stops. No real right or wrong answers. Here's what I did:
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
- You may not post replies
- You may not edit your posts
Forum Rules
