Thread: GTM engine pulley spacing
    Jan 2024
    Does the GTM use the Corvette LS1 or the Camaro/Firebird LS1 belt pulley spacing?
    Corvette spacing on everything. If you're doing a crate engine, you will have to install the older C5 water pump that has the large bell-shaped pulley. The newer waterpumps with the flat pulley are too thick at the t-stat housing and the housing will hit the chassis.
    Shane Vacek
    www.vraptorspeedworks.com
    Jan 2024
    Thanks Shane. Not doing a crate motor, but working on something that requires the proper spacing
  4. Likes VRaptor SpeedWorks, LLC liked this post
    Senior Member beeman's Avatar
    Indiana
    Quote Originally Posted by Power Surge View Post
    Low mount A/C compressor?
    GTM #304 LPE 525hp LS3
    San Diego
    Here is the water pump that I use...
    https://www.summitracing.com/parts/gmb-130-7290
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
